Can your product satisfy our needs of handling larger programs by DNC ?
Yes. We can DNC a program directly from a USB key to your machine.We offer mid-tape start and insertion of preparatory data such as tool change,..
What modifications are required at our end ?
Using the USBCNC, none. You only need to plug power to our unit. We provide a serial cable and connector as well as a 2 GB USB key. The internal version, USBCNC-INT, requires modification to your machine. We have an installation manual on our web site if you wish to review. It mostly consists of drilling some holes on the pendant of the machine and putting our operator interface on it. From there it is pretty easy to pick up power from the machine and connect the serial port. A water proof panel mount USB connector is also provided. This should be placed where convenient for the operator.
Do we have to have the “Okuma DNC-B” option fitted before using your product ?
Yes. Without DNC functionality on your Okuma, our product will only allow you to transfer files back and forth from the machine to the USB key.
Is there a local user (Australia) that uses your product on an Okuma machine that we could view in action ?
Not that I am aware of. I know we have shipped our Fadal USB products to Australia, but it operates somewhat differently from the Universal version and might not be the best test case for you to view.
If this is not a possible solution for your Co.
Can you suggest another possible source or solution that may eliminate the need to retro-fit our machines by purchasing the DNC option ?
Or have the ability to run the larger programs from another data source ?
Based on what I know, I am afraid that unless you buy more memory that will handle your programs, you will be forced to purchase the DNC option from Okuma. Otherwise, you will have to cut your program into smaller pieces and load/run each one. Having a USB key with all the smaller programs could make this a little easier, but it is not an ideal solution.
