603,400 active members*
2,356 visitors online*
Results 1 to 11 of 11
    Sep 2007
    46
    Upgrading from MP03 to MPC6515 controller
    Can anyone help me please?! I contacted my supplier and they said my machine could be converted to the MPC6515 Controller and then I could use LaserCut 5.3; In my mind I thought this was a simple process, however it has turned out to be a little more complicated. I have attached photos of my current controller and the new controller; My difficulty is what wires on the old controller actually are!?
    I know that it needs to be completely disconnected and removed, however I would like to label each wire with a Name!
    I have also attached a PDF sent to me to help me, if you believe that has the answers please let me know!?
    The PDF says I must use a 24 Volt power supply, I will need to get one as my current supply is 5 volts.
    Also the MPC Hardware manual towards the back shows what wires go into the new board, I include it here so that it may help the knowledgable to help me. Thanks in advance, Amos
    Attached Thumbnails Attached Thumbnails control 3 (Large).jpg   New Electronics 1 (Large).jpg   Current Red Dot Machine with Questions (Large).jpg
    Attached Files Attached Files
    Umm the 6515 is PWM based, the moshi and newlydraws aren't.
    Sadly it's not as simple as just changing the pad and board....
    New PSU is a requirement too.
    It's not a simple upgrade
    best wishes
    Dave
    Sep 2011
    296
    Really Very complicated work. I suggest you directly buy another USB mode machine.
    Melody
    [email protected]
    Sep 2007
    46
    Thanks for your replies, however, my current machine currently runs on LaserCut 5.1 and that also uses PWM, This new card, uses LaserCut 5.3 and apart from improvements on LaserCut 5.1 the basics of operation are similar, it seems to me that the main problem is identification of wiring and addition of a 24volt supply?? But that is why I have posted here, for advice. Amos
    Hi Amos,
    That's a little clearer now, what made you upgrade from 5.1 to 5.3?
    Wiring I can't help with , Leetro may be the best people to ask?
    best wishes
    Dave
    Sep 2007
    46
    Dave, I could not get the current software/hardware to work on Windows 7.
    That means another Computer in the workshop, also my understanding is you can do more / better with LaserCut 5.3, Amos
    TBH there is very little difference, to get it to work with Win7 you just need to disable UAC from control panel for the current user.
    The same will apply to 5.3 as well, the benefits just aren't there for the extra it costs to get it working, if your running 12 hours a day 7 days a week then you may benefit on odd occasions but for day to day running you won't notice any real difference.
    best wishes
    Dave
    Sep 2007
    46
    Thanks, I will try that fix before trying anything else, Amos
    Nov 2010
    786
    Hi
    Do not worry. This is nothing special.
    You can do that.
    Now I am a bit busy but send me a private message in the end of week.
    Will help you.
    Now, just mark all cables with numbers and make safe copy of existing wiring.
    Regards
    W
    CNC lasers, constructions, service
    Sep 2007
    46
    W thank you very much, will do so. Amos
    Sep 2007
    46
    THIS is what I wanted
    This is the help I was asking about, see attached breakout sheet for the P68 breakout board, just knowing these makes my intended upgrade so much easier. Amos
  1. Programming a MPC6515 controller
    By CARTOGATE in forum Redsail Laser
    Last Post: 11-14-2018, 05:12 PM
  2. MPC6515 and LacerCut 5.3
    By pcs.zenica in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-22-2014, 08:41 AM
  3. Considering Upgrading Controller, Software, etc...
    By getrolfed in forum Controller & Computer Solutions
    Last Post: 01-16-2012, 03:46 PM
  4. Smoothstepper and MP03 pendant conflict
    By aspley in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-22-2010, 07:41 AM
  5. MP03 pendant -help needed in setting up
    By aspley in forum Mach Software (ArtSoft software)
    Last Post: 06-14-2010, 08:34 AM
