588,193 active members*
6,560 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Upgrading from X to X3
Results 1 to 4 of 4
    Feb 2008
    4
    I have recently installed X3web.exe and used the migration utility to update my existing X files, control file, posts etc.
    Now when I post in X3 using either of my posts, all linear feed rates irrespective of programmed values come out as
    F9999990, Canned cycle feedrates post OK.
    Also stagetool and coolant commands dont post properly, I can live with these shortcomings for now, but obviously feedrates are a different matter.
    I do not Know where my problem originates from.
    Any help would be greatly appreciated.
    Post Names : DMU_EVOLUTION_LINEAR_TNC
    : DMU_MONOBLOCK_TNC
    Control Name : HEIDENHAIN (i)TNC 426/430/530 (CONVERSATIONAL)
    Description : HEIDENHAIN TNC CONVERSATIONAL 5-AXIS MILL POST
    Apr 2003
    3578
    tumchie I think you found the answer on the Mastercam Forum. but I also post about month two ago the info on this here on this forum to.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Feb 2008
    4
    Cadcam.
    Thank you for your reply, After searching both this forum and the emastercam forum for info. It seems that my posts are not mpmaster based. I will be contacting IHS for for instructions on how to tweak my posts or for a post update utility.
    Apr 2003
    3578
    I did not look to see what post you have. the 5 axis DMU is not an easy post. so I would talk with your dealer.In-house does make a really good post for the DMU. I have purchased them for my customers in the past.
    Cadcam
  1. Upgrading my Tree
    By Tom Curran in forum CamSoft Products
    Last Post: 10-20-2008, 07:10 PM
  2. Upgrading Dolphin
    By ImanCarrot in forum Dolphin CAD/CAM
    Last Post: 03-19-2008, 10:13 AM
  3. Upgrading a Shopbot
    By JeffreyMcGrew in forum Commercial CNC Wood Routers
    Last Post: 12-28-2007, 09:13 PM
  4. Upgrading to TCNC 4.1
    By cbcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-03-2007, 09:47 PM
  5. Upgrading a 1993 VF3????
    By sco999 in forum Haas Mills
    Last Post: 04-14-2007, 08:06 PM
