603,942 active members*
2,713 visitors online*
Results 1 to 5 of 5
    Apr 2015
    3
    Question USB Connection Error
    Hello there everyone!
    Not to long ago I lost everything on my computer and had to start all over. Since then I completely forgot what I had done previously to get my engraver to connect to my laptop. I have done everything I can think of and am about to pull all of my hair out.
    Here is what I've done so far...
    -Made sure everything is connected
    -Plugged cord into several ports
    -Refreshed all USB ports
    -Uninstalled and reinstalled RDCam
    -Uninstalled and reinstalled USB driver through RDCam software
    -Installed SM Bus Controller
    -I
    nstalled FTDI driver D2XX
    -Restarted my computer SO MANY TIMES!
    I have a 60w CO2 laser engraver from China [Not sure what else info you may need]. And am running RDCam v8 on my Windows 7 Dell Laptop.
    What more could I do to make this thing work?! If you need any more info just let me know...
    Jan 2008
    940
    Re: USB Connection Error
    Was the other computer a Dell. On my CNC Dells will not run without com errors due to the crappy Dell usb ports.
    Apr 2015
    3
    Yup, before I lost everything it worked.
    Apr 2015
    3
    Well, my laptop can see that the engraver is connected but the program doesn't see the engraver. I have tried laserworks and RDCam.
    Jan 2008
    940
    go into device manager and remove the usb and any yellow checked things then do a scan for new hardware.
  1. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  2. Replies: 0
    Last Post: 07-17-2014, 04:12 PM
  3. Replies: 0
    Last Post: 12-02-2013, 07:47 AM
  4. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  5. Replies: 3
    Last Post: 08-25-2010, 03:04 AM
