587,322 active members*
3,211 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > USB controller card as extra inputs?. (DDCM6\Mach3)
Results 1 to 4 of 4
    May 2014
    8
    I purchased a ddcm6v5 a while back without really looking into it too well. i as hoping to be able to use my laptop to control my 3x2router. bad idea, as a controller it was impossible to find quality documentation on, came with pirated mach, trojaned dll, jogging was horribly latent, stepper movement seemed smooth but was erratic and missing more steps than a drunk sailor.. So i was hoping i could use it on my 32bit win7 machine along with the parralell BoB to give me the extra inputs id like to have. (index, encoder, start, pause, reset) and if possible use the three outputs to run SSR for vacuum, coolant, spindle light. I did give it a quick try with mach but got nowhere (possibly due to a port conflict)? Would i want to choose the parallell port as primary then enable the usb plugin.? I have tried using arduino/modbus for my inputs but i cant seem to completely wrap my head aroudn the registers and mach brain. i briefly had modbus with a jog speed pot and reset button working with a (script?) i found on the internet written by someoen else but i cannot seem to find it again. anyways, thanks for reading
    -jrr
    PS. if you are looking at buying one of these blue DDCM digital dream cards on ebay, do yourself a favor and keep your money. The vendors selling them should all be banned for selling counterfeit softwares and faulty product.
    Mar 2003
    35538
    Re: USB controller card as extra inputs?. (DDCM6\Mach3)
    I believe that the answer is no.
    I believe that the Gecko G100 is the only device that can be used as I/O along with the parallel port.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2014
    777
    A uc300 usb or uc400 Ethernet have multiple idc ports that you can plug more than one idc to dsub cable into to run multiple bobs for extra I/o's.
    May 2005
    1397
    Add another parallel port... cards are like $20.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. extra circular movement in mach3
    By sarsali in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2015, 05:10 AM
  2. Mach3 not consistenly responding to THC inputs
    By LordyGordy in forum Mach Plasma / Laser
    Last Post: 08-17-2014, 05:31 PM
  3. Inputs 1-4 Gecko G 540 Stepper controller
    By itolond in forum Gecko Drives
    Last Post: 04-12-2014, 04:43 PM
  4. Best option for more Mach3 inputs?
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 04-11-2012, 08:32 PM
  5. Anybody get inputs working with GRex and Mach3 ?
    By Argofanatic in forum G-REX
    Last Post: 05-06-2008, 08:56 AM
