603,943 active members*
4,384 visitors online*
Results 1 to 4 of 4
    Sep 2008
    3
    Unhappy USB to RS232 NO Communication?
    Newbee here-
    I purchased a new computer for our shop to upload/download programs to various CNC machines. It Does Not have a 9pin Com1 port but rather only USB. I purchased a Pinicale USB to 9pin Com1 converter, but I am still unable to send/recieve programs to the CNC. I have tried slowing down the baud rate to lowest setting, but still no sucess. I have taken in my personal computer and sent/recieved with it, but it Does have a 9pin com1 port (all setting the same). I can not possibly be the only one with this issue, can someone give me some advise?
    Thanks............Carrie
    Jul 2004
    175
    The problem with USB to serial; its designed for printers, camera, etc with fast communication; it also does not show up as a true 1650 Uart. Thus the communications is unreliable. If you have a laptop; use a PCMCIA or Express card to give you a true port.
    If its a desktop, put in a PCI card $25.00 to give you 2 ports.
    We sell some options.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    Sep 2008
    3
    Thanks Grag for the info. I will give you a call soon to discuss this card. BTW- I have a Toshiba laptop.
    Thanks,
    Carrie
    Jul 2004
    175
    No problem. Then you will need an Express Card or PCMCIA Card to slide into the opening on the laptop. About $100.00 and it works every time vs this random stuff with USB.
  1. What software is necessary for RS232 Communication?
    By 61SedanMan in forum Haas Mills
    Last Post: 08-31-2017, 11:22 AM
  2. RS232 communication on Fanuc 21i-TB control
    By dittrichw in forum Fanuc
    Last Post: 06-09-2008, 12:02 PM
  3. RS232 communication software
    By gar in forum Haas Mills
    Last Post: 08-14-2007, 02:56 AM
  4. Help! RS232 Communication to Fanuc 3T Control
    By m1_machine in forum Fanuc
    Last Post: 10-30-2006, 09:08 PM
  5. Fagor RS232 Communication - No Luck
    By cammo in forum Fagor Automation
    Last Post: 08-17-2005, 06:19 AM
