586,055 active members*
4,176 visitors online*
IndustryArena Forum: USB, RS232, PARALLEL etc
Page 4 of 5 2345
Threads 61 to 80 of 95
Discuss everything USB, RS232, PARALLEL etc here!
  1. RS232 Switch on a New Windows 7 System
    Started by imageman1984, 03-28-2015 01:13 AM
    rs232, software, switch, system, windows
    04-01-2015, 08:07 AM Go to last post
  2. Need some RS232 Help!
    Started by Gunner52, 02-19-2015 09:03 PM
    02-20-2015, 12:36 PM Go to last post
  3. Polaris 2 lathe from 2002 test cable.
    Started by catablue, 02-16-2015 01:51 PM
    cable, cnc, polaris, problem, software
    02-16-2015, 01:51 PM Go to last post
  4. PC to CNC devices for older CNCs (RS232 <--> USB)
    Started by alpinems, 01-30-2015 03:49 AM
    cnc, machines, rs232, via, way
    02-11-2015, 08:18 PM Go to last post
  5. Parallel port card suggestion for Newbie
    Started by moosecnc, 02-08-2015 03:02 PM
    card, cnc, controller, parallel, suggestion
    02-11-2015, 03:24 AM Go to last post
    01-14-2015, 10:18 PM Go to last post
  6. Transfer programs from cnc to pc. Tree, Dynapath
    Started by pgooch, 01-08-2015 04:48 PM
    840, cnc, controller, programs, transfer
    01-08-2015, 04:48 PM Go to last post
  7. Parallel USB
    Started by jw007, 12-28-2014 08:14 PM
    bought, cnc, machine, parallel, usb
    12-29-2014, 01:15 PM Go to last post
  8. LPT woes...ugh
    Started by chemsolder, 11-04-2014 01:15 AM
    bios, board, breakout, build, can o, change, cnc, control, drivers, electronics, first cnc, inspection, linux, load, lpt, parallel, parallel port, port, problem, steppers, type, wire
    11-04-2014, 08:07 PM Go to last post
  9. Help for newbie: USB-Parallel DB25
    Started by eldersoares, 09-28-2014 07:51 PM
    adapter, change, color, data, electronics, font, high, index, machine, motor, newbie, parallel, parallel port, port, product, programmer, project, shop, slot, star, usb, velocity
    09-28-2014, 07:51 PM Go to last post
  10. RS232 Cable Tester
    Started by jrecto99, 09-26-2014 03:57 PM
    cable, can o, db25, ends, est, este, ext, found, hat, problem, put, remo, remote, rs232, rs232 cable tester, serial, serial cable, tes, test, tester, unit
    09-26-2014, 05:35 PM Go to last post
  11. problem RS232 On Intergrex 200sy
    Started by Daarn, 09-03-2014 05:44 PM
    203, code, communication, data, drive, error, error code, function, hard drive, hole, large, machine, mazatrol, memory, mode, network, parameters, problem, problems, program, rs232, tape, work
    09-03-2014, 05:44 PM Go to last post
  12. DNC SOFTWARE FOR DRIPFEED
    Started by jw12, 02-25-2014 08:27 PM
    08-26-2014, 04:28 AM Go to last post
    05-30-2014, 08:12 PM Go to last post
  13. Recommendations for PCI Parallel card?
    Started by adam_m, 05-10-2014 11:51 PM
    board, change, diy cnc router table machines, parallel, parallel port, pci, port, ports, ready, recommendations, working
    05-15-2014, 11:27 AM Go to last post
    03-28-2014, 05:42 PM Go to last post
  14. Serial to USB
    Started by mattlynx, 03-04-2014 09:27 PM
    cable, iphone, laptop, port, programs, rs232, serial, serial port, tapatalk, transfer, transfer programs, usb
    03-10-2014, 05:29 PM Go to last post
  15. Rs-232 from a Heidenhain display unit
    Started by biederboat, 03-07-2014 02:53 AM
    416, adapter, direction, display, dsr, edge, edge finder, excel, files, finder, heidenhain, housing, information, internal, linear, manual, nec, output, request, ring, rs-232, scales, string, terminal, wire
    03-10-2014, 04:12 PM Go to last post
  16. Parrellel and com port?
    Started by Ncrazyballa, 12-25-2013 06:44 PM
    02-10-2014, 10:19 AM Go to last post
  17. LPT and Sparkfun Easy Driver
    Started by john1a, 02-03-2014 12:47 AM
    arduino, axis, breakout, bridge, cnc, drive, driver, drivers, easy, engraver, interface, laser, lpt, mach, mach3, motors, parallel, parallel port, problem, program, star, stepper
    02-03-2014, 12:47 AM Go to last post
Page 4 of 5 2345
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
