588,461 active members*
4,854 visitors online*
    Feb 2006
    57
    Use knee to compensate for tool length changes
    I want to know if there is a way to hook a stepper up the knee and use it for tool heights. Example say you go to use a drill that 6 inches long longer then your endmill. I want the table to move 6 inches negative z when the drill is called. Could you do this using a macro?
    Dec 2004
    1865
    ME WANT THIS TOO.
    Quote Originally Posted by Korellibopper View Post
    Himmykabbible has been looking into doing this and apparently it will have to wait until Mach3 Rev. 4 comes out. In revision 4 it should be possible to send the tool offset to the C axis instead of the Z axis.
    I of course have no idea on how to actually do it but I am in the process of putting a motor on the knee so I can be ready.
    When I have the knee drive all set up, I intend to just go into the G-code and
    Input the values manually. If you know the difference in tool lengths, it should just be a matter of inputting a C (knee) move just after the tool change.
    If somebody else has a different take on this, please speak up.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Oct 2005
    80
    Knee for Tool Offsets
    This is a good idea, I'm interested in hearing more when this becomes available.
    -Brian
  1. Tool length sensing!
    By Swede in forum FlashCut CNC
    Last Post: 05-07-2013, 04:38 AM
  2. Need help with tool length offset
    By panaceabea in forum Haas Mills
    Last Post: 03-04-2009, 08:07 PM
  3. Tool length setter
    By Harryman in forum G-Code Programing
    Last Post: 01-02-2009, 01:14 AM
  4. G43.1 - Tool Axis Direction Tool Length Compensatioin
    By EngTech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2007, 11:01 AM
