603,310 active members*
2,649 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Use of oil for linear bearings and ball screws.
Results 1 to 5 of 5
    Nov 2016
    11
    After cleaning the old grease out of all the linear bearings on the 3 axis router, the quantity of debris insisted on an end seal upgrade. I installed them, but what a job that is!!
    As mentioned, while re-balling 12 linear bearings (Hiwin HGH20), a close look at the inlet leaves no doubt as to why my grease gun was getting stuck on the zerk. Locked on due to high pressure. Always wondered about that. Hindsight is quite a thing.
    As for the ball nuts, there isn't one of the three whose 6mm inlet is even visible, Z and X are prone to more swarf based on proximity to cutting action. The wiper is nearly useless. Even a reputable brand has a really lousy wiper. Is there no upgrade for those?
    Hiwin has a section on suggested lube other than grease. So...
    I thought I would try a manual oil pump and 4mm nylon tube to deliver. For the short term, I'll not run all separate lines through the wire loom which has little extra space anyway.
    One product available in Canadian stores that may suffice is a Mobil Oil product designed for engine break-in period. 2 - 5W range
    I have tested a fairly viscous oil additive for, again, breaking in rebuilt or new motors. Results were less than stellar. The pump seemed to be drawing in as much air as lube.
    First inclination was to thin the product, though it may have been due to an air lock or I just failed to pour enough in the tank.
    I would love to have your feedback.
    Chris
    Jul 2018
    6823
    Re: Use of oil for linear bearings and ball screws.
    Hi Flyer - I use a paraffin wax vs an oil. It leaves a solid wax surface to protect and lub plus being a solid does not attract dust so minimises muck getting into bearings.... Peter
    Nov 2016
    11
    How does one use paraffin. Thanks.
    Chris
    Nov 2016
    11
    Thanks, I replied to the post, not to you, so to make sure you are notified. How is it done?
    Jul 2018
    6823
    Hi Chris - I apply by spray and/or rag every so often. There will be industrial waxes suitable for the job as well. Don't use beeswax. Paraffin and microcrystalline waxes and carnauba are the keywords for machinery. Peter
    Veritas Tool Wax | Carbatec
    Machine and Tool Wax | Next Day Delivery – Rutlands Limited
  1. Bearings on ends of ball screws?
    By akn99 in forum CNC "do-it-yourself"
    Last Post: 11-16-2020, 02:23 PM
  2. Ball screws and angular contact bearings?
    By dowling177 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-10-2013, 10:25 PM
  3. Best place to buy ball screws and linear bearings etc?
    By noobCNC in forum DIY CNC Router Table Machines
    Last Post: 05-21-2012, 11:31 PM
  4. NSK Ball Screws and linear bearings?
    By Burner in forum DIY CNC Router Table Machines
    Last Post: 02-11-2006, 05:44 PM
