587,302 active members*
3,329 visitors online*
    Dec 2005
    1408
    User-friendly lead-free solder
    Hello,
    Here in the UK, we are no longer allowed to use wire solder containing lead. I love tin/lead solder and have used it since the age of eight, a few years ago. It flows well on the tip of the iron and makes a good joint quickly. My problem is that I have to make fifty thru-hole boards in a bit of a hurry, and need to choose a solder wire that flows well without lead, some of which have been horrible to use in the past.
    Can any of you kind people give some suggestions?
    Thank-you
    Edit: We will clean the boards with Safewash. It has worked well in the past
    Edit: with an ultrasonic bath. Here is the Safewash link...
    http://www.elkatek.com.tr/pdf/urunle...sallar/SWA.pdf
    Sep 2010
    1765
    wont help ur 50 boards now, but u might just stop next time u have time at flea market or hamfest and stock back up? thats what we do....
  1. user friendly cam software for 3d toolpath
    By telah in forum Uncategorised CAM Discussion
    Last Post: 08-08-2011, 07:59 PM
  2. User friendly software
    By AJ Negvesky in forum Uncategorised CAM Discussion
    Last Post: 11-18-2008, 12:55 AM
  3. Replies: 0
    Last Post: 04-04-2007, 02:36 PM
  4. free solder paste?
    By fyffe555 in forum CNC Machine Related Electronics
    Last Post: 03-09-2005, 03:17 AM
