603,386 active members*
3,115 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > Using air cylinder in single-acting mode to balance Z axis setup
Results 1 to 10 of 10
    Nov 2008
    421
    Hi, did anyone use air cylinder in single-acting mode to balance Head on Grizzly tabletop mill. After converting to new 2 hp spindle motor I had to slow the z axis waaaaay down..
    Forget about global warming...Visualize using your turn signal!
    Mar 2008
    1762
    Re: Using air cylinder in single-acting mode to balance Z axis setup
    Sure...
    But use a double acting cylinder with a silencer on the unused port. The regulator does the rest.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Jan 2005
    1943
    Why not just use a lift strut like so many others have done.
    Nov 2008
    421
    "Why not just use a lift strut like so many others have done."
    Because I don't have an idea how much oomph I need for my setup. Weighting the head assembly and motor is out of question. By using cylinder I can easily adjust the air pressure needed.
    Not only that.. I do have a couple of air cylinders that would be perfect for this, I think.
    Jan 2005
    1943
    But an air cylinder will need to have a way to to pressurize it and de-pressurize it or it will lock the motion. of the head.
    May 2006
    27
    Quote Originally Posted by lancut View Post
    I did this on my gantry router 4 years ago. Works perfect. Pressurize one side of the air cylinder. Put a breather or regulator on the other port of the cylinder. Put a regulator on the air supply to the cylinder to find that happy spot where the head is just about weightless.
    Sent from my SGH-T399N using Tapatalk
    Jan 2005
    1943
    I see now. I thought you were just plugging one end of the cylinder.
    Nov 2008
    421
    Quote Originally Posted by bodini View Post
    Thanks for the reply. That's exactly what I want to do.
    May 2006
    27
    Here is how my system is set up. AIR COMPRESSOR > CHECK VALVE ON AIR TANK ON MACHINE > AIR TANK ON MACHINE > PRESSURE REGULATOR > AIR CYLINDER. Like I said, the other side of the air cylinder has a breather valve.
    You could just hook to a compressor, but I wanted the piece of mind that once the small on-board tank (3 or 5 gallon, i forget) is charged the system would not fail because of an unhooked air hose. It will hold all day on one charge (could be longer, I've never cared to notice).
    Also, I set a pressure switch on the tank, hooked it to Mach, and if the tank is not pressurized enough, it lights an LED.
    I just checked and the air pressure is set to about 90 psi to make the head nearly weightless. When the head goes down and the air compresses back to the system, it reads about 93 psi at the holding tank.
    Reply with a question if you want any more info.
    Nov 2008
    421
    Thanks for the details. I have compressed air at the machine and all the parts needed, air pressure regulator, pretty good size manifold, etc.. It should be no problem to get this going. Thanks again.
  1. Advice on a simple single axis setup
    By Kevman101 in forum Stepper Motors / Drives
    Last Post: 05-03-2013, 03:38 PM
  2. MX-46VAE ATC arm single side mode
    By Algirdas in forum Okuma
    Last Post: 08-04-2010, 10:04 AM
  3. motogp or F1 Single cylinder research engine
    By jlcortes in forum I.C. Engines
    Last Post: 07-03-2010, 11:10 AM
  4. Auto mode only after single block
    By fomaz in forum Fanuc
    Last Post: 04-17-2010, 10:53 AM
  5. single cylinder engine drawings?
    By savvypower in forum MetalWork Discussion
    Last Post: 02-01-2007, 12:44 PM
