588,117 active members*
5,024 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > using bur instead of undercut endmill?
    Feb 2016
    34
    I need to add detail to a side wall of a wood part (hard maple) using a 3/16 round lollipop end mill. I've come up with two tool options that will have the needed clearance: A) a 270 degree undercut ball end mill or B) a carbide bur with approx. 277 degrees..
    http://www.harveytool.com/ToolTechIn...olNumber=41312
    https://www.mcmaster.com/#42955a25/=17t4bub
    The speeds and feeds will be be slow since its a finish pass removing at most .015" of material at a time.
    The bur is 1/5 the cost - any advice out there? anyone used carbide bur's for milling ?
    Feb 2006
    7063
    Re: using bur instead of undercut endmill?
    I think the question is how many flutes on the cheap one? It doesn't say. The picture indicates it has very fine teeth, which would not be great for wood. But the pictures are often not accurate. For $11, I'd just order one and try it out.
    Regards,
    Ray L.
  1. V27 3 Axis Undercut
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-16-2015, 11:55 PM
  2. Help/suggestions for undercut tooling
    By erikpurne in forum Vacuum forming, Thermoforming etc
    Last Post: 11-29-2013, 06:25 AM
  3. Help undercut
    By togr in forum Mastercam
    Last Post: 04-26-2013, 05:43 AM
  4. how can i cut angled contours (undercut)
    By guzelali in forum CNC Machining Centers
    Last Post: 12-30-2010, 01:01 AM
  5. Machining an undercut in Rhinocam?
    By mike stables in forum Rhino 3D
    Last Post: 01-22-2008, 01:25 PM
