603,344 active members*
3,958 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Using a Chucking Reamer
Results 1 to 11 of 11
    Oct 2008
    2205
    After calculating the speed and feed for a chucking reamer do you rapid for the retract, or do you maintain the same speed and feed for the retract?
    Bob La Londe
    http://www.YumaBassMan.com
    Jan 2006
    2985
    I use the same speed for retract. In my experience a rapid retract will tend to leave a spiral score in the bore.
    Oct 2008
    2205
    Quote Originally Posted by keebler303 View Post
    I received a reply in another forum from somebody I respect who half agrees with you. Yes a rapid retract will leave a light spiral score mark, but it is superior to allowing the imperfections of the machine, lineup, etc to cut the overall size of the hole larger from a slow retract. You use the reamer to get to a very close to perfect size, but allowing it to wallow around in the hole any longer than absolutely necessary will oversize the hole.
    Bob La Londe
    Apr 2012
    90
    If your machine is a pos then yes it can ream oversize feeding back out. But chucking reamers are designed to follow the hole so feeding out shouldn't make much of a difference. If you're worried about it reaming over on the feed out and spiral marks you can also stop the spindle then retract.
    Jan 2006
    2985
    Quote Originally Posted by AARONT View Post
    But then you have straight marks instead of spiral marks. Ahhh!
    Sep 2006
    6463
    Hi, I always rapid retract....the reamer is not a boring bar, it is designed primarily to cut a bore to size rapidly as opposed to boring it out with an adjustable boring bar, so as time is the reason you use a reamer......rapid retract.
    The fact that you may leave scratch marks on the bore is irrelevant........if the finish is that important, hone it out to size afterwards.
    Ian.
    May 2013
    44
    We feed in and out at the same speed. Size and finish are equally important for most of our parts.
    Sep 2006
    6463
    Hi, reamers are designed to cut on the end (corners) not the sides, so withdrawing the reamer will not cut any more material out of the bore, but it will leave a rub mark as the reamer comes up the bore.
    If you are feeding the reamer out at the same rate as you feed in you're wasting time which is money.
    When a reamer is sharpened it is ground on the corners only.
    If you grind the OD of a reamer, you don't have a reamer anymore.....not at that size anyway.
    Ian.
    Mar 2008
    240
    Quote Originally Posted by handlewanker View Post
    Ian.
    Second that.Juergen
    Apr 2012
    90
    What if you use a spiral flute reamer...:cheers:
    Jan 2006
    2985
    You got me! :wave:
  1. changing chucking direction
    By crazycnc in forum Fanuc
    Last Post: 06-25-2016, 07:08 AM
  2. SL-10 - Chucking
    By jpthorpe1041 in forum Haas Mills
    Last Post: 03-19-2012, 02:10 PM
  3. New Guy with Chucking Reamer Questions
    By MetalShavings in forum Benchtop Machines
    Last Post: 12-29-2009, 01:47 AM
  4. Chucking on Tapered Hex
    By Tazzer in forum MetalWork Discussion
    Last Post: 01-18-2009, 02:18 AM
  5. spline chucking
    By reachraghu in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-09-2007, 09:14 PM
