603,360 active members*
4,527 visitors online*
    Jan 2017
    28
    Using Circular saw blades on Miter Saw
    Hi all,
    I've got a technical question of sorts. I have both a circular saw and miter saw. The circular saw uses 230mm (9") blades but the miter uses 255mm (10") blades. Can I use circular saw blades on the miter saw?
    Aside from the fact that they spin in the other direction, would there be other issues with this? The bore is the same 25.4mm (1").
    There are many stainless steel blades for circular saws that come in 230mm (9") and 305mm (12") sizes for circular and chop saws but none that I have found in 255mm (10") size for miter saws. I don't know why that is.
    Thanks for your input,
    Mar 2003
    35494
    Re: Using Circular saw blades on Miter Saw
    Yes, you can.
    But be aware that there are differences. Miter saw blades tend to have a negative rake angle, which prevents them from grabbing the wood, which makes them safer. Circular (and table saw) blades often have a high positive rake angle, which can grab the wood and lift it when used on a miter saw.
    But if you are an experienced user, and hold the stock firmly in place, you shouldn't really have any issues.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2017
    28
    Thanks ger, I'm more interested in using some steel blades that are exclusively for the circular saw, from Evolution.
    Do you think there is much difference in a Stainless Steel blade vs Regular steel blade? According to the manufacture, the SS one has 60 tooth compared to 48 tooth for the regular (mild) steel. Both blades are carbide tipped.
  1. 135 Degree Miter Fold Bit?
    By grsims20 in forum CNC Tooling
    Last Post: 03-15-2017, 07:26 PM
  2. miter flange
    By julio_gyn in forum Bending, Forging, Extrusion...
    Last Post: 05-02-2014, 01:55 PM
  3. CNC tips for using a Lock Miter bit
    By siggma in forum WoodWorking Topics
    Last Post: 06-03-2013, 10:57 PM
  4. Miter saw for solid ALU bars?
    By PEU in forum MetalWork Discussion
    Last Post: 08-14-2008, 01:02 PM
