587,143 active members*
4,566 visitors online*
Results 1 to 4 of 4
    Apr 2012
    161
    Question Using IF [] statements in PathPilot
    Can you do conditional execution but not in a subroutine in PathPilot? I'm trying to do this:
    IF [#5400 EQ 516] G52 X1.2129 Y-1.0493 Z0.4972 (Position Tool #516)
    IF [#5400 EQ 502] G52 X1.0592 Y-2.4673 Z0.5034 (Position Tool #502)
    IF [#5400 EQ 501] G52 X1.0662 Y-3.8448 Z0.0381 (Position Tool #501)
    But I get an error on the "IF" word. I've never used subroutines or conditional execution in gcode before.
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Apr 2017
    158
    Re: Using IF [] statements in PathPilot
    Each if needs a matching endif, where oh-numbers are used for the matching. Your code should be something like
    o1 if [#5400 EQ 516]
    G52 X 1.2129 Y -1.0493 Z 0.4972 (Position Tool #516)
    o1 endif
    o2 if [#5400 EQ 502]
    G52 X 1.0592 Y -2.4673 Z 0.5034 (Position Tool #502)
    o2 endif
    o3 if [#5400 EQ 501]
    G52 X 1.0662 Y -3.8448 Z 0.0381 (Position Tool #501)
    o3 endif
    This assumes that o1, o2, o3 are not used elsewhere, even in subroutines, so you'll need to set up and follow some rules for keeping track of these.
    Apr 2012
    161
    Thanks, I'll try that
    Apr 2017
    158
    Quote Originally Posted by Fenichel View Post
    o1 endif
    o2 endif
    o3 endif
    Even better, since the various cases are mutually exclusive, would be
    o1 elseif [#5400 EQ 502]
    o1 elseif [#5400 EQ 501]
    o1 endif
  1. Biessework and statements
    By Puuseppo in forum Biesse
    Last Post: 01-28-2024, 08:57 PM
  2. if statements...
    By deadlykitten in forum Okuma
    Last Post: 11-07-2015, 01:46 AM
  3. Format Statements
    By Xavior in forum Mastercam
    Last Post: 09-08-2011, 12:28 PM
  4. comment statements
    By compfranon in forum ArtCam Pro
    Last Post: 09-04-2011, 02:13 AM
  5. If / Then Statements
    By Nanker in forum G-Code Programing
    Last Post: 10-23-2004, 06:11 AM
