Now that I know enough about "G" codes to be dangerous I'm ready to advance to the next level. Just did a couple of runs on my newest CNC mill.
I have an Axxus control board that the computer plugs into and the Gecko driver boards wire into. This board also has termals for 5 inputs and 4 outputs. The 4 outputs use pin #1, #16, #14 and #17
Now, can I assume these outputs are for turning on the spindle, coolant pump and other periferal devices?
I know that M03 code is supposed to turn on the spindle and M05 stops the spindle. Which outputs does MO3 turn on? Is there a place in the software to match up "M" codes with pin numbers?
M07 turns on coolant on relay "A" and M08 turns on relay "B".
Appreciate some pointers on this,
I'll try these "M" codes and see if something happens at the outputs untill I here from someone.
Thanks,
Jim
