603,371 active members*
4,079 visitors online*
Results 1 to 9 of 9
    May 2007
    327
    using Mach software for digitizing?
    can this be done? any tips appreciated thanks !! Rich
    I need to scan a fairly large object..
    Mar 2003
    35494
    There's a plugin that uses a webcam and laser, but there's very little documentation for it.
    http://www.machsupport.com/forum/ind...oard,67.0.html
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2007
    11
    You can use touch probes also, like one from IMS service or a Renishaw type contact probe. You have to keep in mind limitations of a probing setup. Don't have time to go into it but ball diameter can cause some problems, depends on how accurate you have to be. Also the length of the probe may limit you also since you mention it is a big part. I have a renishaw setup I run with MAch 3 so I have some experience.
    May 2004
    21
    Digitization
    Hi
    Not really that hard to do. Please see my photos of my home made touch probe.
    You can either run a wizard from the mach 3 screen ( Wizards, pick wizard, digitization wizard) or download the probe plugin from the Mach Artsoft website.
    You will have to connect the touch probe to an unused input and configure it in Ports and Pins in the Mcah main scrren and then you are in business.
    Any questions please ask and I will try and steer you in the correct direction.
    My homemade probe is extremely successful and I get about 0.007 mm variance if I probe a flat object, however this goes up to about 0.05 if I run the vertical probing speed at 400mm/min (the former figure is at 50mm/min)
    Best regards
    Peter Williams
    Attached Thumbnails Attached Thumbnails DSC03770.JPG   DSC03771.JPG   DSC03767.JPG   DSC03769.JPG
    Dec 2003
    199
    Quote Originally Posted by Rich05 View Post
    If you are scanning something large then the mach "wizard digitizing" program will be mind numbing slow.
    Unfortunately the later version add-on is non functional as far as I can tell.
    Mach 2, 3, are really great software but forget about using the digitizing part of it.
    L
    Is a sentance fragment?
    Aug 2007
    339
    I just put a laser pen into the spindle held lightly by a collet and tool holder. Lay the object on the table and go around it drawing it on the laptop using the numbers given by the readout on the machine. I use Alphacam to draw and cut but you can also use anytype of drawing software. Use 3 points to define your archs' and Radii. This is very simple and only cost me $3.50 for the Laser pen. I have done a lot of decking for Yachts using this method working from their paterns both paper and wood when they could not supply the drawing.
    We all live in Tents! Some live in content others live in discontent.
    Mar 2003
    35494
    He wants to do 3D probing over a surface.
    Gerry
    Aug 2007
    339
    ahh. It would have been nice if he had stated that.
    Sep 2004
    So is Rich still watching this thread or what? If so did you ever get your part digitzed Rich? What was it anyway and what solution did you come up with?
  1. Help needed with Mach 3 and Art Fenerty Digitizing Wizard
    By Evolution VIII in forum Digitizing and Laser Digitizing
    Last Post: 09-17-2010, 11:27 AM
  2. using a CNC / Mach software for digitizing? other ideas?
    By Rich05 in forum Digitizing and Laser Digitizing
    Last Post: 01-14-2009, 05:12 PM
  3. mach 2, xylotex and homemade digitizing probe
    By gun_mike in forum Benchtop Machines
    Last Post: 03-17-2008, 02:50 AM
  4. Digitizing software?
    By DennisCNC in forum Digitizing and Laser Digitizing
    Last Post: 01-15-2007, 04:40 AM
  5. Graphic digitizing software
    Last Post: 10-25-2005, 12:54 AM
