587,224 active members*
3,930 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Using Mach3 with a 4 axis foam cutter
    Jan 2006
    19
    Exclamation Using Mach3 with a 4 axis foam cutter
    Hello,
    I've setup my 4 axis foam cutter to run through Mach3, all works ok when in jog mode & running a demo cut file, if you hit move to zero X,Y & 4 axis go to zero but Z stays put until the other three are at zero then this moves to zero. What's worrying me is if you have to stop the machine & go to zero all the other axis return then z starts it's move after the other have reached zero.
    I understand when using a router that goes to a safe height until everything is at zero to prevent gouging & tool breakages.
    How do I configure X & Z axis to go to a safe height before moving to zero
    Jan 2005
    1880
    probably a better idea to ask in the mach3 area instead of the foam cutter area
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Jan 2006
    19
    Quote Originally Posted by miljnor View Post
    Ok thanks I'll try that :cheers:
  1. Mach3 R3.00 Mill 4 axis Foam cutter setup
    By Andy Smith in forum Mach Mill
    Last Post: 01-25-2008, 02:19 PM
  2. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  3. MS Excel 4 Axis CNC Foam Cutter Experiment
    By arman in forum CNC Wire Foam Cutter Machines
    Last Post: 10-25-2006, 09:04 AM
  4. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
  5. Foam cutter
    By paulried in forum CNC Wire Foam Cutter Machines
    Last Post: 10-30-2003, 10:58 PM
