603,400 active members*
2,755 visitors online*
    Jan 2013
    58
    Using Nitrogen with Powermax 105
    Has anyone any expirience with using Nitrogen for cutting stainless steel on a Powermax 105?
    I have just changed from a TD A120 Cutmaster on my Blue Marlin to the PM 105. Previously with the TD I had used Nitrogen to cut up to 4mm s/s @ 40 amps with quite good results but the TD rep told me that 40 amps was the maximum otherwise the electrode would melt.
    I now have some 15 thick s/s to cut with my new Powermax 105 and I see from the manual that I would need to use 85 amps for any piercing.
    I could of course just use compressed air but on the thinner materials the Nitrogen gave a much cleaner cut.
    Jan 2008
    2247
    You can use nitrogen at any power level with the Powermax105. My experence shows a better cut with air in terms of edge angularity and dross....the nitrogen may provide a slightly less oxidized surface. If you have a water table....raise the water to about 6mm above the plate surface and use nitrogen for the best edge on stainless.
    N2 on steel will not provide good results. Air and N2 are the only gases approved for use in the Powermax systems.
    Jim Colt Hypertherm
    Quote Originally Posted by Simonh1959 View Post
  1. cutting 12 ga cr with nitrogen
    By Acedart in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2011, 05:06 PM
  2. Laser Users Lower your Costs with Free Nitrogen!!
    By NitrogenBill in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-25-2009, 03:28 PM
  3. Nitrogen for cutting gas? (Question for Jim Colt)
    By magma-joe in forum DynaTorch
    Last Post: 12-11-2008, 06:34 PM
  4. advantages of using nitrogen?
    By anthony in forum Waterjet General Topics
    Last Post: 12-05-2005, 05:04 PM
