603,936 active members*
3,767 visitors online*
Results 1 to 5 of 5
    Apr 2015
    using Polypropylene for cnc structure?
    so yeah i was thinking that instead of using mdf for my cnc i could use polypropylene since it is a plastic it wont't be affected by humidity and it is pretty rigid. the machine at first will be used for cutting 2 mm thick aluminium wich i will then use to reinforce the structure, my plan is to be able to machine copper, aluminium, plastics and wood. this are the steppers i will be using for the machine i will also be using 16mm linear shafts and ballscrews, the intended machine lenght will be 60 Cm x 50 Cm.
    sorry for the grammar and formating english is not my main language.
    Jul 2009
    419
    Re: using Polypropylene for cnc structure?
    Don't go there.
    PP is not rigid, not dimensionally stable and temperature sensitive. It is a recipe for disaster.
    Well, it may be possible to build a good router out of PP somehow, but it will take a huge effort and that could better be used for something else.
    If you are worried by humidity, use mdf or better, HDF and epoxy to build a torsion box router, covering every bit of mdf with epoxy in the process.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Apr 2015
    And what do you think of the motores?
    Jul 2009
    419
    Seems ok.
    "using 16mm linear shafts" i'd go for 20 mm, but either way, make sure they are supported shafts!
    Unsupported flex too much.
    Sven
    Jan 2007
    1795
    just check on prices first..
    acme screws already cost same, or even more sometime than ballscrews..
    v-rollers, unsupported round rails also cost same than supported rails.. hiwin square rails you also can find in this price range and this would be the best..
    for structural parts use steel square or rectangle tubes, for the lowest price..
    don't sve a couple of dollar to not using aluminum for the sides..
    shark cnc actually has some hdpe sides, and other parts, also it using acme scres, or simple threaded rods (?)
    some folks likes it, some don't,,,
    but no folks went to shark after they used any other rotuer..
    for motors, just go with a kit where you get all parts and you can build it..
    pending on where you located, in usa keeling inc
    in Europe go to cnc drive
    CNCdrive - motion controls
    you also can check aliexpress, and ebay...
  1. Settings thin polypropylene sheets
    By AnjaV in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-12-2014, 09:35 AM
  2. Polypropylene for CNC Router table top/deck
    By CNC Pro123 in forum DIY CNC Router Table Machines
    Last Post: 08-29-2013, 03:34 PM
  3. Cutting Porous Expanded PolyPropylene (P.E.P.P)
    By BuckeyenNJ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2012, 02:47 PM
  4. Need Help Fast!!! CNC machining PP/polypropylene
    By Alicia in forum Community Club House
    Last Post: 03-18-2010, 02:23 PM
  5. Routering sheet PolyPropylene
    By planeflier in forum Material Machining Solutions
    Last Post: 05-01-2006, 04:10 PM
