588,240 active members*
4,272 visitors online*
Results 1 to 6 of 6
    Apr 2007
    3
    Cool v-carve in mm
    Hi guys
    I download z v-carve demo version to check my new router that I build my self. But I have difficulty using the program because it can be setup in inches only not in mm.
    Help please,,,,,,,,,,, any one
    Apr 2005
    3634
    To change from inch to mm, try this.
    Start Vcarve:
    1) Edit
    2) Material Size
    3) Units (it defaults to inch, change the radio button to mm)
    4) Click the OK button
    Free DXF - vectorink.com
    Apr 2005
    3634
    After you change from inch to mm, you'll need to redo the toolpath (code), the program will let you know, that this needs to be done anytime you change the material size, etc...
    Aug 2005
    597
    Perfect answer - Thanks Switcher
    serocco - I hope your new router is up and running and if you need assistance or have any questions drop an email to [email protected] and we'll see if we can help out.
    Tony
    Apr 2007
    3
    thanks guys thats help a lot keep the good works running.
    cheers
    Apr 2007
    3
    cheers
  1. V Carve pro and Busellato
    By JET 3006 in forum Vectric
    Last Post: 03-07-2008, 11:10 AM
  2. V Carve
    By tangocc35 in forum Joes CNC Model 2006
    Last Post: 10-17-2007, 09:18 PM
  3. Help using v-carve trial
    By nydheart in forum Vectric
    Last Post: 04-02-2007, 05:46 PM
  4. V Carve PRO demo
    By craigy85 in forum Commercial CNC Wood Routers
    Last Post: 10-13-2006, 09:43 PM
  5. V Carve possible changes
    By Brian P in forum Vectric
    Last Post: 09-11-2006, 09:32 PM
