588,202 active members*
3,939 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V21 decimal point adjustment needed
    Oct 2006
    157
    Hello to all !
    How do you get the dimension to list the exact distance . Mine is rounding things. It only goes out two digits after the decimal ,like exact distance between the centers of 2 circles might be 12.875 but it lists 12.88 , makes me think I drew it wrong .
    How do you adjust this setting ?
    Thanks for the help!
    Jul 2009
    219
    How to set dimension decimal places
    To change or set your decimal places for the dimensions,
    just right click in the workspace, then choose attributes. Next pick dimension, under vakue is where you set your decimal places.
    Eric
    Oct 2006
    157
    Thank you . I knew it would be something easy .
  1. decimal point Gcodes G90.1 G91.1
    By Karl_T in forum CamSoft Products
    Last Post: 10-22-2009, 08:24 PM
  2. Forcing a decimal point from a pci
    By inflateable in forum EdgeCam
    Last Post: 10-28-2008, 02:58 PM
  3. Illegal use of decimal point
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 07-08-2008, 12:06 AM
  4. decimal point
    By stevieboy in forum Mastercam
    Last Post: 01-10-2007, 12:42 PM
  5. Decimal point placement
    By Zeekh in forum Haas Mills
    Last Post: 11-05-2006, 02:18 AM
