I loss power and have had to autoexec load the software since the batteries decided they were tired also. Since this has happened my files from surfcam do some strange things. It will start an arc and not stop, but complete the section and the rest of the circle. Should I reformat the harddrive and reinstall the software? I took the file to a friends machine and it ran fine, so I know it is originating with my machine as the problem. I am not quite sure of the answer.
One other thing I was wondering is the 30-35 psi asco switch went out at the same time and I have a 40-45 psi switch in house. Would it hurt to use this instead of the harder to find 30-35 unit? The pressure on the line is 60psi. comming in.
Ron in limbo
