603,959 active members*
4,836 visitors online*
IndustryArena Forum > CAM Software > Mastercam > v9.0 help with windows XP?
Results 1 to 9 of 9
Hybrid View
cncboss6 v9.0 help with windows XP? 06-02-2007, 05:58 AM
dolphin1 have you set the pathway to... 06-02-2007, 06:07 AM
cncboss6 It is under the correct... 06-02-2007, 06:33 AM
Steve Arteman Go to my computer, tools(at... 06-03-2007, 11:26 AM
cncboss6 Thanks Steve, I will give... 06-12-2007, 02:56 PM
cncboss6 Yes Steve that worked. Now I... 06-12-2007, 03:08 PM
Steve Arteman Pat, Im glad it worked! it... 06-13-2007, 04:27 AM
ObrienDave On a similar note, I had... 06-24-2007, 10:25 PM
Steve Arteman Good one! Thanks Dave. 06-25-2007, 11:52 AM
    Mar 2005
    81
    Hello Guys, using Mastercam 9.0 with Windows XP. when I go to get a file and load it, I cannot see all the Mastercam 9 files unless I select all files even though they are mc9 files. Other people I know have had this problem with XP. I could see them in Windows 98. Thanks
    Jun 2007
    7
    have you set the pathway to the folder where your files are.
    Mike
    Mar 2005
    81
    It is under the correct directory, some show up but not others until you click on all files. Thanks
    Go to my computer, tools(at the top),folder options,view, click show hidden file and folders, uncheck hide extention of known file type. hope this helps
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Mar 2005
    81
    Smile
    Thanks Steve, I will give that a try.
    Mar 2005
    81
    Smile
    Yes Steve that worked. Now I can see all the files with the mc9 file option. Thanks again, Pat
    Pat, Im glad it worked! it can be enough to drive you nutty if that doesn't work
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Jun 2005
    305
    On a similar note, I had someone tell me that all of their files had "disappeared".
    Curious, I went over and had a look at their computer.
    Turned out that someone had set the font color to the same as the background color.
    Hence, the "disappearance" of their files.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    www.cad2cam.net
  1. windows dro
    By the4thseal in forum CNC Machine Related Electronics
    Last Post: 03-28-2016, 11:37 PM
  2. Dnc and windows emulator
    By camtd in forum LinuxCNC (formerly EMC2)
    Last Post: 02-25-2007, 01:08 AM
  3. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
  4. Windows Xp
    By i228208 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2004, 03:57 PM
