603,355 active members*
3,768 visitors online*
    Vacuum system upgrades.
    5 years ago we bought a Forsun CNC.
    The vacuum is generated via twin 3000w 18amp liquid ring pumps.
    The steel tank is now rusting badly.
    One motor has failed due to seizure. Possible from metal flakes in the water.
    What tanks do you use.
    Polythene? Or painted / galvanized steel ?
    As it’s time to rip it all apart I need to change the tank.
    Any suggestions please.
    I’m leaning g towards a polyethylene cube.
    Dec 2003
    1344
    Re: Vaccuum system upgrades.
    Pressure vessels tend to be cylindrical and for good reason but if your tank is just a liquid container to replenish the system,plastic may be a durable answer.You don't seem to have a huge amount of power for the pumps,do they work adequately?
  1. The method About Handle Operating system upgrades
    By Baiansy in forum Machines running Mach Software
    Last Post: 04-11-2015, 02:39 AM
  2. Coolant system upgrades
    By SWATH in forum Mikinimech
    Last Post: 01-20-2015, 07:55 PM
  3. Torus Pro Coolant System And Enclosure Upgrades
    By SCzEngrgGroup in forum Novakon
    Last Post: 04-15-2013, 08:15 PM
  4. vaccuum table use
    By joemc in forum Commercial CNC Wood Routers
    Last Post: 10-22-2007, 05:33 AM
  5. precix vaccuum table
    By joemc in forum MetalWork Discussion
    Last Post: 10-18-2007, 01:47 PM
