603,321 active members*
3,381 visitors online*
Results 1 to 4 of 4
    Aug 2006
    39
    Vacuum hold down
    Hope this isn't in the wrong spot...a year or so ago I was researching vacuum hold downs for a 4'x8' Cnc. There was a company that made a vacuum machine for the somewhat diy'er. Black box I believe it was. I can't find it anymore? Sound familiar to anyone? I thought I'd seen someone use it on a pro 4896?
    Jan 2015
    194
    Re: Vacuum hold down
    Black Box Vac Home
    And if you really wanted to go down the DIY route you could buy the vac motors and make your own black box. Realize though that this will require lots of research on your part to figure out how to build the box to get good performance and not burn up your motors. Much easier to just buy the Black Box. The Lighthouse 7123 is the most popular one. And make sure to buy the gaskets. I've also seen people use the motor with overdrive listed at the bottom of the page.
    ShopBot Vacuum Motors
    David
    Aug 2006
    39
    Thank you sir! Just what I was looking for.
    Jan 2008
    940
    Go to the Shopbot forum and search Black box and there are plans there
  1. Vacuum pump size for vacuum hold down jig?
    By dawgwalker in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2014, 03:07 AM
  2. Vacuum hold down
    By Bill Sines in forum Material Machining Solutions
    Last Post: 09-13-2012, 03:05 AM
  3. Vacuum Hold down?
    By wendtmk in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-23-2010, 04:02 PM
  4. hold down vacuum system
    By alfonsonog in forum DIY CNC Router Table Machines
    Last Post: 02-10-2008, 08:11 PM
  5. 4x8 Vacuum Hold Down
    By elogicca in forum DIY CNC Router Table Machines
    Last Post: 07-24-2007, 02:06 AM
