587,228 active members*
5,886 visitors online*
Thread: Vacuum Jigs?
Page 1 of 2 12
Results 1 to 20 of 27
    Nov 2007
    980
    Vacuum Jigs?
    Ok, I'm still very new here and did a search and found bits and pieces about these but I'd like to know what you use. I'm going to be doing some engraving in some small parts and would like to create a jig block with a cavity to hold them with a vacuum pump system to get away from taking the time to screw each one down to a block or use a double face tape.
    I'd love to see pics of your setups, construction and/or hear about your success or lack of with these. If I have posted this in the wrong area, possibly you could direct me to the right place...this form is huge!
    Many thanks-
    EDIT: Well I see there is a workholding forum so please feel free to move this. Sorry 'bout that-
    Dave->..
    Mar 2004
    169
    Go to joewoodworker.com Anything you want to know about vacuum work holding is there.
    Nov 2007
    980
    Thanks for asnwering and yes, I've been there but saw no "nesting" type setups, only veneering setups and vacuum tables. Possibly I missed it?
    Dave->..
    May 2006
    1469
    Quote Originally Posted by fretsman View Post
    Look at this link for my effort.
    http://www.cnczone.com/forums/showthread.php?t=34537
    Also do a search on the forum for vacuum. You will see a few threads with different ideas.
    Greg
    Nov 2007
    980
    Quote Originally Posted by Greolt View Post
    Greg
    Actually Greg, you have inspired me already before you posted here, lol! I saw some of your videos on youtube and have enjoyed learning from them. The link you provided clears up all the questions I had for you so thank you very much for your time and info.
    Specifically I'm looking at making nesting fixtures that have the shape of each part that I'll be engraving and those will be interchangable on top of a main vacuum housing. If that makes any sense. lol!
    Dave->..
    May 2006
    1469
    This makes perfect sense to me. If I was doing similar repeat jobs I would do exactly this.
    I can imagine the fixture having a common base with the vacuum connection. This would stay fixed to the table.
    Then having job specific fixtures that fit onto the common base with positive location and seal.
    Each of these fixtures would then have the job specific shape of seal and appropriate locating dowels or shoulders etc. to locate and hold that particular job.
    Both base and fixture together would not need to be more than 20 to 30mm high.
    In the right situation this would be well worth pursuing. Good idea. :cheers:
    Greg
    Feb 2008
    23
    Smile Vacuum fixtures
    Just so happens I'm working with a vacuum plate now . may be able to get some pics of it . New here and have my own problem with a machine . Basically , took a 1" thk. plate that I could shape my profile in and room for some plumbing parts . rectangle say 5" X 7 " . my parts have two small cavities in bottom so I cut into my plate the depth needed , ( +.003 ) on profile , don't want to much play. and gave myself another (.030) wall offset of that profile and put in a o-ring . So I have 2 profile pockets and a o-ring profile close to shape .
    Added 4 more smaller ( .375 ) dia. in 4 corners . took plate out and started drilling 1/4" dia holes to intersect where the o-rings are. plugged in ( 3 ) 1/4" pipe taps ( 2 ) in one side ( 1 ) in the other . Used plastic 90 deg elbows and some plastic hose that fit the couplings.. Also bought a tank from msc . To suck any coolant I may get and put a relief valve in it .. I cant believe the time i have saved on this set up .
    I have a old vacuum pump that gets something like 24 lbs of vac.
    It holds parts taking (.400 ) dp cuts and 25 " fd rate and hold them flat .
    Crazy . Very in expensive to thing we spent maybe $300 in materials .
    Hope this gives you some new thoughts on how this may work for you.
    Tony
    May 2006
    1469
    Got any pics Tony.
    Always easier to understand the description.
    Greg
    Nov 2007
    980
    Yes, Tony, that is exactly what I was looking to do and using O rings was the same idea I had as well since I'll be working with fairly small parts (no bigger than 3" X 3").
    As Greg mentioned, if you ever do get any pics I'd love to see them.
    Welcome to the forum and thanks so much to you guys for your help-
    Dave->..
    Aug 2005
    197
    when i make vacume fixtures I make a scroll (spiral) in the pockets pending thickness of the material for the spacing of the walls. then on the outside (not connected) cut an oring groove. The groove will take a few trys on exact depth, I found that 40 - 80 durometer?? type o-ring to work the best. Also I only have a crush depth of a .005-.010 as if two much will not flatten down. also place a vacume in the center via cross drill.The magic vacume numbers seem to be 27 + inches an automitve airtype vacume pump works great as coolant does not seem to effect it. it does however require lots of shop air.
    hope this helps.
    Nov 2007
    980
    Quote Originally Posted by Verfur View Post
    hope this helps.
    Thanks, it did help but may I ask you to be a little clearer on this sentence?
    It's a vacuum pump, no?
    Any chance you might have a pic or 2 of the setup?
    Thanks again!
    Dave->..
    Mar 2003
    35538
    I think he's using an air powered venturi vacuum generator.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2007
    980
    Ah, I see, thank you sir-
    Dave->..
    Feb 2008
    23
    Vacuum Plate
    Ok guys ,
    Took pictures today and lets see if I can show you what I did.
    Not sure if I can write once pics are up so bear with me . 1st time sending pics.
    Basically I made up my fixture plate to hold part, Attached some plumbing to it to a pump and tank so as i could release pressure and hold vac from take. if that makes any sense. Pics hopefully are in order of hook-up.
    Here goes. ALSO SORRY ABOUT PIC'S SAVED AS CHRISTMAS 2007 . DOWNLOADED ALL THE SHOTS ON CAMERA AND NAMED THEM THE SAME FOR EVERYTHING.
    Attached Thumbnails Attached Thumbnails Luke Christining, Christmas 2007 058.jpg   Luke Christining, Christmas 2007 059.jpg   Luke Christining, Christmas 2007 060.jpg   Luke Christining, Christmas 2007 061.jpg
    Feb 2008
    23
    Vacuum plate
    Hopefully you can see how i made if you can enlarge the shots. Tank has to hose fittings at top of tank , one goes to the release valve that i made and mounted on table in machine. 2nd goes to pump. The pump is on floor and (1) hose from it to tank. The pump is old and when we tried to figure how much suction we could get we got like it was equal to a 33 lb weight on part. Didn't sound like much and may even be wrong all together. BUT all I can say is we wittle out parts faster and flater that we could before . WE also changed to Carbide 3 flute high helix , running twice as fast than before and feed rate about 30% more.
    These things work,
    Hope this helps .
    Aug 2005
    197
    is right.
    sorry about that
  17. #17
    Aug 2005
    197
    looks nice do the o-rings flatten down all the way???
  18. #18
    Nov 2007
    980
    Excellent pics, thanks for putting them up for us. As was asked above, I'm thinking since O rings are fairly "solid" and don't compress much, you probably only have them a couple of thousandths above the surface?
    Thanks again-
    Dave->..
  19. #19
    Mar 2003
    35538
    Plenty of O ring alternatives at www.allstaradhesives.com
    Gerry
  20. #20
    Nov 2007
    980
    Thanks for link, Gerry
    Dave->..
Page 1 of 2 12
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  2. CNC Machined Dovetail / Finger jointing jigs
    By ALAN2525 in forum WoodWorking Topics
    Last Post: 08-13-2008, 08:38 PM
  3. Tips, Tricks and Jigs
    By Regnar in forum DIY CNC Router Table Machines
    Last Post: 11-27-2007, 07:31 AM
  4. How much vacuum?
    By nbuchholz in forum Open Source CNC Machine Designs
    Last Post: 05-25-2006, 10:46 PM
  5. Screwless vise hold down jigs? who sells them
    By replicapro in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2006, 06:01 PM
