588,385 active members*
5,258 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Variable Parameters 31 and 32 Citizen/Fanuc Controls
    Jun 2013
    42
    I know 0031 and 0032 are X and Z grid shift parameters for my machines but I am not sure what the values represent in measurement. I have a machine that's off around 1.5 inches on the top turret but only off 1/8 inches on the bottom. The X grid shift parameter is set at 0. This is kind of confusing since 0031 is the only X grid shift parameter I know of. Any ideas????
    Sep 2011
    261
    Make a large shift, make a simple part in MDI and measure the difference. like just turn .100 under stock dia and measure the difference before and after. Turn your Rapids down to 5% or use dry run to make sure you dont crash. Fanuc controls are usually 1000 in a bit = 1mm so 00001000 grid shift would be 1mm.
    CNC Product Manager / Training Consultant
    Jun 2013
    42
    Yes thank you, I had to wrap my head around the fact that the parameter wouldn't look anything like the actual distance I was going, finally got it up and running correctly just by process of elimination on the math.
  1. Parameters for Citizen E32 swiss lathe
    By JOlalde in forum CNC Swiss Screw Machines
    Last Post: 11-30-2018, 06:50 PM
  2. Need Parameters QT-35 with T-2 Controls
    By capefear17 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-28-2018, 05:32 AM
  3. Interact 4 parameters and TNC controls
    By m4martin in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2013, 12:54 PM
  4. Replies: 0
    Last Post: 04-01-2011, 08:31 PM
  5. mit parameters for citizen L316
    By richard booker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-13-2008, 09:22 PM
