588,174 active members*
4,138 visitors online*
    Oct 2007
    34
    Variable Radius
    Hi Guys,
    I am quiet new using Solidworks and doesn't have formal training. I learn it by myself.
    Now I'm stumble upon a problem of creating some sort of variable radius on my part.
    I attached 2 files, 1 is .dwg file and the other is solidworks part file.
    On .dwg file , I have 3 colors of entities. :
    Red is to be R8, Blue is to be R3 and Yellow is to be a progression radius.
    Hope you guys can help me with this, and please forgive my bad english.
    Thanks in advance
    Best regards,
    David Saimi Sulong
    Malaysia
    Attached Files Attached Files
    Jun 2008
    562
    A variable radius will not work where there is a partial radius. You will need to do a cut-loft I think. Create your different profiles at the start and stop of the different radiuses and use the corner edge as a guide curve. See the help menu.
    Good Luck
    Mike
    Oct 2007
    34
    Mr Mike,
    Thanks a lot sir for your prompt reply. I will certainly try it later.
    I'm very lucky to stumble upon this very useful website, and lucky enough to received reply from a good people like yourself.
    It's inspired me to share with others. Above all, sharing is caring.
    Thanks again sir.
    Best regards
    David Saimi Sulong
  1. Variable radius fillet mastercam X5
    By D.L in forum Mastercam
    Last Post: 03-06-2012, 01:47 AM
  2. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  3. Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 05:28 AM
  4. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
  5. Problem with variable radius fillet
    By gibsonc in forum Solidworks
    Last Post: 05-15-2006, 05:13 PM
