Need to change the drive belt as part of VS head rebuild on a Clausing/Kondia FV-1-CNC. The manual shows all the bearings needed, and lists the belts needed too. (the same parts are used in the manual VS head).
The problem is the part number for the variable speed belt listed isn't coming up with anything when I search, nor does search using the info on the installed belt!
Anyone able to cross reference a Conti 20-85, or a Roulunds Roflex-Vari 1040?
Many thanks!
Tony
YOUNGER EYES AND FLASHLIGHT .... the part, in case anyone needs it, is ROFLEX 37J0910FR, available in the US for about $55 from JD-belts.com (looks like a good source for VS belts x-references)
