Try reading what I posted very early on; it is technically correct. Vaseline would work perfectly well as a lubricant on machine ways. I just find it quite amusing that people put so much store in way lube. What is the difference between it and regular machine oil. Also what is the intent behind a manufacturers recommendation? Why would grease be used in place of way oil and vice versa? Do they provide equal lubricating capacity? The ballscrews and linear guides are the same manufacture on machines that use way oil so it is not something that is specific to the equipment.
