I posted this on the CandCnc list and thought I would ask here too.
I have something going goofy here with my voltage up and down buttons.
When I click the up or down arrow buttons the voltage doesn't change, But when I
click the stop button after the arrow buttons then it will change the value in
the readout box by the number of times I pressed the arrow button. But it will
not send the change to the THC box. I can still change the voltage on the THC
box with the buttons there and it works fine.(the height control)
The table value and xfer buttons work fine.
I have compared the VB scripts for the buttons and it appears to be the same as
on other screen sets.
This is an MP1000c-THC.
This seems to have happened after a power outage. Could that have changed
anything?
I also had a monitor quit at the same time. I don't know if they are related or
not.
I have rebooted several times, reloaded Mach to V 3.042.037, the problem started
on an older version so I downloaded the newest version.
I have searched old posts here and on the CandCnc list and haven't found anything
related, hope you have some ideas.
I am not dead in the water but I'd like to get it back to working again.
Thanks, Steve
