603,960 active members*
3,867 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Vcarve Pro won't start my router spinning
Results 1 to 9 of 9
Hybrid View
Gary-Wiant Vcarve Pro won't start my... 09-02-2017, 12:07 PM
mactec54 Re: Vcarve Pro won't start my... 09-02-2017, 01:51 PM
Gary-Wiant Re: Vcarve Pro won't start my... 09-03-2017, 04:29 AM
ger21 Re: Vcarve Pro won't start my... 09-03-2017, 12:25 PM
Gary-Wiant Re: Vcarve Pro won't start my... 09-03-2017, 12:45 PM
Gary-Wiant Re: Vcarve Pro won't start my... 09-04-2017, 02:30 AM
mactec54 Re: Vcarve Pro won't start my... 09-04-2017, 02:46 AM
Gary-Wiant Re: Vcarve Pro won't start my... 09-04-2017, 03:55 AM
mactec54 Re: Vcarve Pro won't start my... 09-04-2017, 04:39 AM
    Jun 2017
    370
    When I send a job created & toolpaths saved in V-carve Pro 9 I have to manually start the router but when the job is done V-carve will turn the router off. Am I missing something in the setup? When I create toolpaths in DeskCNC it will start the router by itself.
    Also not related but still in V-carve, I noticed that when routing a pocket the toolpaths alternates clock wise & counter-clock wise which is fine but when it alternates the tool picks up to Z Home then back down and starts routing again. The videos I've seen on youtube the machines don't do that.
    Thanks for the help.
    Gary
    Jan 2005
    15362
    Re: Vcarve Pro won't start my router spinning
    Quote Originally Posted by Gary-Wiant View Post
    Gary
    Post the start of the program (Cut/Paste it ) it could be as simple as missing the start command ( M3 16000S ) or what ever RPM you are running
    Mactec54
    Jun 2017
    370
    Ok I'll try to get that tomorrow or Tuesday at the latest.
    I'm using a variable speed router, I don't have a spindle yet so it would be different line right?
    Mar 2003
    35494
    If you are using the standard Desk CNC Inch post processor, there are no commands in it to start and stop the spindle.
    I'm guessing the DeskCNC is stopping the spindle when it sees an M2 at the end.
    If that's the case, you need to modify the post processor to add the appropriate commands.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2017
    370
    Gerry, thanks I'll look into doing that.
    Jun 2017
    370
    Here is the photo of the monitor for the last job I routedClick image for larger version.
    Jan 2005
    15362
    Yes just add the line like I said, at the beginning
    G0Z800
    G0X0Y0.
    S12000M3
    Mactec54
    Jun 2017
    370
    Do I need to add that on every job or it there a way to have it show up every time I import a job.
    Jan 2005
    15362
    If your postprocessor does not put it in the program, the postprocessor would have to be modified, or you would have to put it in in each program / job if you want the spindle to turn on
    Mactec54
  1. First Start with VCarve Pro 6 0
    By nayefacc in forum PhotoVCarve and VCarve Pro
    Last Post: 10-04-2015, 11:26 PM
  2. Spindle won't start spinning on Multicam
    By lettersetc in forum EnRoute
    Last Post: 09-23-2015, 09:32 PM
  3. Replies: 5
    Last Post: 11-01-2011, 11:15 AM
  4. How does the router know where to start?
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-21-2011, 01:10 AM
  5. Replies: 1
    Last Post: 11-15-2007, 01:51 PM
