603,330 active members*
4,224 visitors online*
IndustryArena Forum > CAM Software > Vectric > VCarved Wooden Sign
Results 1 to 4 of 4
    Aug 2005
    597
    VCarved Wooden Sign
    Below are a couple of pictures of a VCarved Wooden Sign we recenty machined using a Roland EGX cnc machine.
    The machine cut really smooth and quick with very impressive results.
    Tony Mac
    [email protected]
    Dec 2004
    1316
    I think my coffee table is in trouble :devious: . The top is a thick Mahogany slab that I can carve something into. I will tell the wife it fell out the window and only the top survived.
    Nice pictures Tony. Keep them coming.
    Jason
    Dec 2003
    259
    Tony, Two questions:
    How long to cut and what is the font ?
    John S.
    Aug 2005
    597
    Hi John,
    This 'Rustic House Sign' has been v-carved into a slice of Silver Birch 530mm (21") x 200mm (8") on a Roland EGX 600 Engraver. A 100 degree included angle engraving cutter, running at 12,000 rpm and 20mm / sec (0.75" / sec) cutting at multiple Z levels, carved the complete sign in approx 15 minutes.
    To simplify the finishing process the wooden blank was varnished before vcarving. The letters were then vcarved and painted, with the excess paint simply wiped off the flat surface.
    The whole front of the sign was then varnished again to make it weather proof.
    This type and size of signage will retail for at least £35+ - $60+
    The text is simple Times Roman
    Regards,
    Tony Mac
    PS Has anyone heard from 'Grizzmo' recently?
