588,169 active members*
4,176 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > VDI 40 Live tooling
Results 1 to 8 of 8
    Aug 2005
    35
    VDI 40 Live tooling
    Would anyone share their recommendations for radial vdi 40 live tooling. This is for a 2007 Okuma Captain L370 BBMW.
    Jun 2015
    4169
    Dec 2008
    3136
    Re: VDI 40 Live tooling
    Apr 2009
    1262
    I tend to like the Exsys (Eppinger) for milling because they use tapered roller bearings rather than ball bearings, so they take the side loads better. They also come with a 2 year warranty. 1-800-EXSYS4U.
    WTO and Von Ruden also make some pretty decent toolholders that will fit your machine.
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4169
    you can replace bearings, even exchange with other types
    Attached Thumbnails Attached Thumbnails b1 rad.JPG   b2 ang.JPG   b3 tprd.JPG   b4 axl.JPG
    Jun 2015
    4169
    open them, see how they work
    there are lot more merchants than producers, so consider contacting a producer, and buy only the big box and rest of parts, do them yourself
    Apr 2009
    1262
    I've opened Alps (Okuma std.),Sumatic, WTO, Sandvik, Command, Sauter, Von Runden, EWS, and Exsys and Rebuilt most of them at some point.
    Now you know why I'm suggesting Exsys. Viton seals, Tapered roller bearings, better warranty than most, good rebuild service, tools are pre-run in so they arrive ready to go.
    Not saying some of the others don't do some of the same, but in my experience, they will last longer and be more rigid.
    Let the gunfire begin!:argue:
    Best regards,
    Jun 2015
    4169
    i had no problem with mines ... a polar bear makes them .... about tools pre-run, hmmm ... if quality-control is done at every step, than you can avoid pre-run
    even more, you can avoid final optical machine measurements, by using certain conditions when crafting them
    actually, i had problems with live-straight-holder, but i guess is understandable : i was doing parts with >300 holes, and after 2-3 shifts, inside seals got wasted ... well, only one holder worked all the time ) ... at that moment i started to repair them ... understand them ... got attached
  1. how do i use the live tooling
    By firekoe in forum Fanuc
    Last Post: 08-06-2012, 02:44 PM
  2. Replies: 2
    Last Post: 08-09-2010, 04:17 PM
  3. LIVE TOOLING?
    By WOLOG in forum OneCNC
    Last Post: 03-17-2009, 08:46 AM
  4. live tooling
    By guhl in forum Fanuc
    Last Post: 02-12-2008, 08:43 AM
  5. What is Live tooling versus "non-live tooling"?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2007, 09:38 PM
