588,404 active members*
4,807 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Vectorless Drive Spindle Speed Calibration
Results 1 to 16 of 16
    Oct 2004
    159
    Decided to check my actual spindle speeds (PCNC 1100 w/vectorless drive upgrade) against the input value, and this is what I got. It's not BAD (less than 5% error over most of the range), but I'm wondering if it could be better. Is this comparable to what the rest of you are seeing?
    The frequency value at 500 RPM input is 34.6, exactly what it should be per the Tormach calibration procedure. I checked the Emerson Commander SK manual for tips, but nothing jumps out at me.
    Is there a way to massage this curve, or should I just nudge the input value on critical jobs to get the correct actual RPM?
    TIA
    Sep 2012
    1543
    Re: Vectorless Drive Spindle Speed Calibration
    I would prefer it just like your graph shows actually, atleast its not the other way around.
    Feb 2006
    7063
    Don't know why you'd care about a few percent, especially since it's a few percent high. Getting it close will gain nothing.
    Regards,
    Ray L.
    Jan 2012
    51
    Quote Originally Posted by dkaustin View Post
    Thanks for sharing. Can you give us a little more info on how the data was acquired - specifically, how did you measure the spindle rpm?
    Regards,
    Geo
    Jun 2006
    2512
    Correct cutting speed is a long, long way from an exact science. Your graph as is looks way better than good enough, even for the most critical of the most critical operations.
    Phil
    PS: What do you think the correct rpm would be before the advent of the VFD.
    Oct 2004
    159
    Yes, I agree that, as a practical matter, the error is unimportant as far as milling cutters are concerned. I checked the speeds because I am working up the nerve to try some tapping, and I thought accurate speeds would be critical for that.
    Geo, I checked the actual RPM using a hand-held laser tach. Of course, I'm assuming the tach is accurate
    Nov 2010
    360
    A tension/compression head takes that worry away, especially when actual vs. commanded is that close. I tap on my 1100 all the time, no issues so far.
    Dec 2003
    24220
    TIA
    Sensorless Vector?
    The only way to get closer with a VFD is with an encoder option.
    V/F has no feedback, Sensorless Vector relies on the controller electronically sampling the current/voltage/frequency, so what you are seeing is pretty good, IMO.
    Al.
    Albert E.
    Dec 2008
    740
    The spindle speed can be calibrated using the Tormach PCNC Config utility. Mine was about 12% too fast at the top end and I saw no reason NOT to adjust it.
    Step
    Dec 2012
    194
    I agree with dbrija, its not that significant an issue. I have checked my 1100 at low and high speed. I was at the time also concerned about tapping. My spindle spped at 400 setting is 389 so if you program 411 you get 400. Frankly I see no difference between the 2 settings. The T/C takes care of the difference.
    At a 4500 I get actual of about 4800. Never measured the speed when set at 5000 but maybe i'm getting more then the 5000 max. Doesn't seem to matter one way or the other.
    Jun 2006
    2512
    The spindle speed will vary depending on the magnitude of the applied load in any case.
    Phil
    Mar 2008
    216
    I did a calibration on my series 1 spindle speed after upgrading to the new
    series 2 & 3 spindle drive.
    Based on my measurements you could get the actual unloaded RPM to be
    within +/-3% of the commanded RPM everywhere. I will need to redo all of
    this after finishing my upgrade to the Series 3 steppers and drivers since
    the control board is also being replaced as part of that upgrade. YMMV.
    See the two attached for the actual data plots. Note that the actual speed
    is slightly parabolic rather than exactly linear.
    Attached Thumbnails Attached Thumbnails TormachSpindleSpeed.gif   TormachSpindleSpeedError.gif
    Feb 2006
    7063
    Unloaded spindle speed is really a pretty useless number. What you really should care about is the spindle speed under load, which WILL be less than the unloaded speed, unless your spindle has a closed-loop speed control. Even then, a few percent is of no consequence. Reminds me of an old saying: "Measure it with a micrometer, mark it with chalk, cut it with an axe". Speeds and Feeds are approximations, with FAR more than a few % error inherently built into them, due to the many uncontrollable factors involved. A spindle that is off by 5% will have no measurable negative effect on machine operation, and a spindle that is accurate under all conditions to within 0.001% will have no measurable benefit to machine operation.
    Regards,
    Ray L.
    Jun 2006
    3063
    For tapping, it might be best for accuracy to be greatest at low speeds, though the T-C heads probably eliminate most concern there. I generally tap at 500 rpm for 1/4" and under holes and have had no problems there. I generally use SpruutCAM to create the code and the post defaults to a 10% feed adjustment which has been working fine. That is much greater than the speed error you documented so I would be inclined to leave your setup alone.
    Mike
    Sep 2012
    1543
    Great thread here, and MichaelHenry brings an excellent point. Tapping at a lower speed is the Only way to "Safely Assume" you are ok without knowing the exact spindle speed.
    May 2007
    1026
    I also use a T/C head, and I've had it work fine with the FRO accidentally set to 80%. While I wouldn't recommend it, so long as you're within the excursion of the head, it can soak up an awful lot of error.
  1. Replies: 2
    Last Post: 03-31-2010, 01:58 PM
  2. Fanuc 5T Spindle Drive Speed
    By Dragoon2 in forum Fanuc
    Last Post: 12-25-2009, 03:49 AM
  3. Spindle speed calibration
    By Fastest1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2009, 05:25 PM
  4. FR-SE AC Spindle Drive - speed & direction input
    By kudos in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-16-2009, 11:01 PM
  5. Syil X3 Mill Spindle Speed Calibration Procedure
    By Chrisjh in forum Syil Products
    Last Post: 01-12-2008, 08:54 AM
