603,965 active members*
2,454 visitors online*
    Jan 2012
    33
    Velocity change while jogging?
    I'd like to be able to change the jog speed while moving. Anybody know if this can be done? I am simply trying to control 2 axis speed and direction based on a digital 4 function joystick and 1 analog trigger. Direction works fine, speed works fine but cannot change on the fly. Using kflop + snapamp + kanalog
    Thanks, Shannon
    May 2006
    4091
    Hi Shannon,
    I don't understand why that doesn't work for you. A Console Jog Command should perform a blended change from one velocity to another while honoring limited Acceleration and Jerk. You can test this by typing various Jog commands on the Console Screen and observe the effect. Try that and see if it blends properly.
    Regards
    TK
    http://dynomotion.com
  1. EMC Jogging Too Fast
    By pyrojon in forum LinuxCNC (formerly EMC2)
    Last Post: 03-31-2009, 01:46 PM
  2. jogging
    By mr.merlin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-01-2007, 01:48 AM
  3. Cutter velocity change on ARC feeds
    By 9 1/2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-01-2007, 06:42 PM
  4. jogging
    By nebyeh in forum DIY CNC Router Table Machines
    Last Post: 12-20-2006, 01:27 AM
  5. Jogging problem
    By dmgdesigns in forum Mach Software (ArtSoft software)
    Last Post: 10-21-2005, 09:08 PM
