Any ideas on how to add an endplate to a curved part.
I created a boat keel fin with the Extrude a Curve under Solids Menu. I then unioned a cube on the top of the fin to create a 'T' to have a flange to bolt the keel to the bottom of the boat hull.
I then created two parts by splitting the part in half down in the 'l' of the keel and flange. I am making a pattern that will be used to cast the complete part.
The flange was two tall for the 'Z' on my CNC router. So I split the part into two parts so I can rotate the flange on its top and route the plate, fillet and part of the keel fin that I intend to glue back on to the fin.
Problem now is that the tool path generated treats the curve as a hollow part and routes out the back side of the curve down to the 'top' of the flange.
Can I add an end plate to the part, convert it into a solid some how or will I have to redraw that part to extrude the short curve with an end plate?
Sam
