603,319 active members*
2,660 visitors online*
Results 1 to 11 of 11
Hybrid View
    Sep 2015
    12
    Vertial milling machine
    Hello, i work on some weekends on my first cnc vertical mill. The progres is pretty slow due to time and money. This is what i made so far. All parts still needs to be machined, squared and so. For the guides i have 25mm thk for the y axis. The rest for the z and x axis needs to be purchased, but i'l go with 25mm. Here are two videos with my progress so far. Thank you for watching.
    https://www.youtube.com/watch?v=B1kdXgYmyXk
    Jul 2018
    6827
    Re: Vertial milling machine
    Hi Calin - Heavy metal is looking good. Peter
    Sep 2015
    12
    Quote Originally Posted by peteeng View Post
    Thank you!
    Jul 2012
    109
    Your 1 axis "surface grinder" is very cool
    Sep 2015
    12
    Quote Originally Posted by jackjr-123 View Post
    Thank you!
    Sep 2015
    12
    Making of a nut seat for the ballscrew nut with 3 jaws lathe.
    https://www.youtube.com/watch?v=dcubuhzYXu0
    Also, how can i post a ytb video here on forums?
    Dec 2003
    1344
    Quite easily,you copy the URL of the video and then click the icon at the top of the reply page that looks like a couple of frames of old style film,this brings up a dialogue box into which you then paste the URL.It is likely to appear in your reply as a bracketed piece of text but the magic of cyberspace will make it appear in your post.
    Sep 2015
    12
    Hello, here is a video i made and i wanted to share with you where i have done a steady rest for the lathe at my work. Hope you like it guys!
    Sep 2015
    12
    New little update, working on a bt30 spindle. Here is a video with my progress so far. Thanks for watching!
    Sep 2015
    12
    Hi, i made a video of a cheap diy heat treatment owen wich is needed to heat treat my bt30 spindle. Thanks for watching, hope you like it.https://youtu.be/ZbYlLUwgPjI
    Sep 2015
    12
    Hi, i want to share with you, just another lathe toolpost drill/mill attachment made by myself. Thanks for watching!
    https://youtu.be/DWKdWV0BZ_E
  1. Milling a plastic with a CNC 770 milling machine
    By Edmond Young in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-12-2013, 02:55 PM
  2. CNC Vertial Turning Tools
    By yifei in forum Want To Buy...Need help!
    Last Post: 04-01-2012, 07:36 AM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
