Re: Very rough surface finishing recently with c-beam build
Originally Posted by
robwiacek
Agreed. Lubricant is a must.
With the extension of the bit, it is possible to make a clean cut, but it has to be a slower feed rate and a lighter touch.
HSS is not ideal here, eh?
Tool extension and lack of rigidity aren't carbide friendly although carbides have become less brittle. Add into the mix a less than ideal spindle.
On my X2 mini-mill I avoid carbides and get much better results than pictured here. Also my max rpm is half a router's min rpm.
Since your router can't be dropped to mini-mill rpm I suggest lots of passes of small engagement and decent feed rate. Lube helps and compressed air if you've got it
Edit/ I looked at a feed/speed calculator for HSS and you're kind of between a rock and a hard place with the available rpm.
Anyone who says "It only goes together one way" has no imagination.
