603,784 active members*
17,723 visitors online*
Results 1 to 10 of 10
    Jan 2005
    24
    Vexta Stepper Motor Specs
    This is my first thread here, but recently I picked up 4 Vexta Stepper Motors, and the only information I have on the motors is that they are Vexta Mo. C7463-9212KGM, 5.7V, 1A, VP7, 00517, 2-Phase 0.1º/Step, 6-wire lead (Black, Yellow, Green, Red, White, Blue).
    I called the Oriental Company for tech support and they said they coulnd't release specs on the motor cause it was prioritary?
    Basically if anyone has information here as far as what each color lead is?
    and then just any specs as far as power, speed, etc?
    Will these work with Jgro's DIY CNC Router?
    Well I hope you guys can help me out
    Jason
    Dec 2003
    24260
    winding 1
    BLACK outer 1a
    YELLOW center tap
    GREEN outer 1b
    Winding 2
    RED outer 2a
    WHITE center tap
    BLUE outer 2b
    If you give physical size I may be able to match it up as close as possible. you have the voltage and current.
    Al
    Albert E.
    Jan 2005
    24
    they are about 2 3/8 x 2 3/8 and about 3 1/8 deep, 1 1/4" shaft, that is 1/4" dia
    Dec 2003
    24260
    It looks like the one's you have, have a custom stack length with makes the holding torque a guess, based on the physical size and the current/voltage I would say around 100oz-inch holding torque.
    Al
    Albert E.
    Jan 2005
    24
    is there enough info there to know if they'll work?
    Dec 2006
    13
    VEXTA motors & Drivers details needed
    I am also have same question to ask.
    I have 4 VEXTA Model UTH 599 A, 5 Phase, DC 1.4 AMP,. 404 OHMS.
    and 4 Drivers Model USX 5114 need more details could not get fom any ware. Can some body guide from ware I can get all technical specification.
    Thanks. Masroor
    Sep 2006
    42
    hi i also need a guess on motor size i just bought 3 vexta steppers on ebay for $56 i called oriental motor co with the model no. but they said no info because it was a custom motor specs are 4.4v 2.5a 1/8 2phase i didnt get them yet but they look bigger than my 190oz steppers that i have now.anyone have an idea what size they are? there are a few more sets of 3 up for auction might be a great deal? i took a gamble i will try em when they get here.
    Jan 2006
    8
    Here is the link for the 5114 driver manual.
    http://www.alltronics.com/mas_assets/acrobat/24M006.pdf
    Cheers,
    David
    Mar 2011
    132
    if anyone can give specs on Vexta A4722-9215KM .72 24Vdc id very much appreciate it.
    thanks
    Keith.
    Mar 2011
    132
    hello again
    i dont know if this will help anyone but it sure does give alot of info on vext step motors single and 5 phase units
    http://ftp.cnchungary.com/Varsanyi_P...0VEXTASTEP.pdf
    i hope this is right,im not exactly sure how to post a link in a thread if that doesn't work then im sure a google search will turn it up. the PDF name is as follows
    50vextastep.pdf
    hope this helps
    Keith.
  1. Find Vexta stepper parameter
    By tivoidethuong in forum Stepper Motors / Drives
    Last Post: 04-06-2005, 12:59 AM
  2. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  3. Vexta Stepper motor Torque
    By lsippell in forum Stepper Motors / Drives
    Last Post: 06-11-2004, 08:48 AM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
