587,227 active members*
3,215 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Vexta Stepping Motor NEED HELP
Results 1 to 10 of 10
    Mar 2007
    10
    CAN ANYONE TELL ME ANY THING ABOUT THIS MOTOR,AND CAN I USE MY StepMasterNC SOP-1 1 axis bi-polar stepper motor drives
    Vexta Stepping Motor C8384-9212H 2-Phase
    2.5 VOLTS 4.4 AMPS
    SQ7 01598
    ORIENTAL MOTOR CO. JAPAN
    Attached Thumbnails Attached Thumbnails 3vexta-2.jpg   3vexta-3.jpg   3vexta-5.jpg
    Jan 2007
    634
    Someone else may correct me, but I really don't see a way for those motors to be a good match for that controller no matter how they are wired. Sorry.
    Jun 2007
    16
    how many wires are on these steppers?
    Jan 2007
    634
    Easy there Stepmaster guy. I know you want to pimp your product and that it cures the sick and all, but my advice that this wasn't going to be a good match had nothing to do with your brand specifically.
    Quite simply, a motor requiring 4.4 amps unipolar will still need over 3 amps run bipolar series, and well over 6 bipolar parallel.
    It will work, of course, but if you can explain how any driver delivering only around 60% of the power it needs will give a good match for this motor I'm all ears.
    Jun 2007
    16
    If these are 8 wire unipolar motors they would most likely work fine for most applications. No, you wouldn't get 100% rated torque more likely upwards of 85%. Guess what? For most small appications that is fine. I wouldn't recommend purchasing steppers rated above a drives output, but if they are what is on hand, they may be fine for your application. Most people halve amperage rating when modifying unipolar motors for bipolar use. Effectively the amp per phase will be slightly higher than half the labeled amperage, but it is hard to pinpoint this point when modifying steppers.
    Mar 2007
    10
    keepitsimple they are 4 wire motors
    what would be a good driver for them
    Jan 2006
    245
    The Keling KL- 5056 Microstepping Driver is a very good driver.
    or the
    Quote Originally Posted by simplicity View Post
    Motion Control Products Ltd
    www.motioncontrolproducts.co.uk
    Aug 2004
    3215
    Any bipolar driver with 4.4 amp capability, Keling, Gecko etc.
    Jun 2007
    16
    The stepmasterNC drive will drive them, but if you need the full torque, you will certainly need higher amperage output drive
    Apr 2007
    26
    Quote Originally Posted by keepitsimple View Post
    So would a half amp driver, the driver you are talking about would deliver only half the current that this motor needs and has a max voltage of 30V so really you are looking at supplying it 24V max or the bemf can over voltage the driver.
    Running at only 24V and half the rated current would give a terrible performance.
    most likely have the speed and torque than using the msd542 or the kelling driver (At 45V) that that mcp spoke about (Why are mcp advertising a competitors product?)
  1. Vexta 5-phase stepping motor
    By landart in forum Stepper Motors / Drives
    Last Post: 01-29-2011, 08:18 PM
  2. Stepping Motor Sanyo-Syn 103-820-2
    By chockstef in forum Stepper Motors / Drives
    Last Post: 06-10-2009, 10:05 AM
  3. NEED HELP WITH STEPPER Motor PLEASE
    By simplicity in forum Stepper Motors / Drives
    Last Post: 04-29-2007, 01:59 AM
  4. Where to buy stepping motor
    By birdofcnc in forum Stepper Motors / Drives
    Last Post: 01-13-2006, 12:21 AM
  5. Vexta 5- phase stepping motors ?
    By landart in forum DIY CNC Router Table Machines
    Last Post: 09-07-2005, 02:17 AM
