603,861 active members*
3,997 visitors online*
Results 1 to 9 of 9
    Oct 2006
    99
    VF-3 coolant problem
    So we got the new 5, but all of a sudden my coolant flow dropped to nothing on my 3. Motor is pumping, impeller looks good, just no flow what so ever. I peg it to the old machine being jealous of new one. But what does it entail to clean out the system to get flow back up and running.
    Jul 2005
    12177
    The quick attempt at a fix is to take the fitting out at the spindle housing, disconnect the hose from the pump and blow air backwards through the lines. Have somebody hold the hose in a container with something to prevent splashing.
    If you are lucky this will blow out all the chips that have accumulated at corners and constrictions in the coolant lines.
    If you are not lucky now you start taking covers off to take the lines apart and clean them separately.
    Before firing up the pump again get a water filter like Home Depot sells for filtering tap water, and plumb the coolant flow through this.
    Jan 2005
    1880
    do you use these kind of filters geof?
    and if so how long do they last before replacement?
    and lastly do you have a picture of one?
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Jul 2005
    12177
    Quote Originally Posted by miljnor View Post
    First question....Yes.
    Second question....It depends, anywhere from two months to more than six months depending whether we are running much Delrin.
    Third question....Aw heck you would ask that; yes I do, actually it is posted in a thread somewhere but I forget which one. Somewhere in the Haas forum.
    You go look for it.
    Jan 2005
    1880
    1st answer ....thanks
    2nd answer....thanks
    3rd answer.....thanks i guess
    4th answer....Grouch!!!
    thanks
    Michael T.
    Jan 2005
    1880
    I found the picture!
    so your off the hook but still a grouch!
    but you knew that already, didn't you?
    thanks
    Michael T.
    Jul 2005
    12177
    ....but still a grouch! ....
    Don't say that, HuFlungDung will accuse me of muscling in on his territory.
    Jan 2005
    1880
    I haven't seen Hu post in quite some time!
    So I think your Safe!
    thanks
    Michael T.
    Mar 2003
    4826
    Bump
    First you get good, then you get fast. Then grouchiness sets in.
  1. Coolant foaming problem
    By Larry Myers in forum Sharp CNC
    Last Post: 01-26-2016, 09:55 PM
  2. Haas programmable coolant unit problem
    By xs-speed in forum Haas Mills
    Last Post: 01-30-2008, 06:54 PM
  3. Coolant problem
    By Smackre in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2007, 08:47 PM
  4. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
  5. Sour Smelly Coolant Problem
    By widgitmaster in forum MetalWork Discussion
    Last Post: 08-09-2006, 06:40 PM
