587,235 active members*
3,623 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF-3 pcool constantly homing
Results 1 to 5 of 5
    Sep 2005
    26
    I have a 2004 VF-3 with the pcool nozle. When adjusting it up or down it will at no specific interval return home then come back down to the tool. What could be the cause?
    Jul 2005
    340
    pcool goes up for homing or when it detects a manual manipulation of the noozle. maybe because of huge vibrations ?
    Apr 2008
    65
    The switch inside isn't being triggered, possibly bad or misadjusted.
    Jul 2005
    12177
    Quote Originally Posted by horst007 View Post
    You may be out of luck. I have a couple of machines about that age and the pcools did just that; wander off to the end of its travel. On one machine I had it replaced three times during the warranty and the technician said they were a poor design. Later machines do have a completely different unit
    Nov 2007
    1702
    Is this the black PCOOL or the gray one with the red Haas logo?
    I have the one with the gray logo--November 2004 VF-2--similar to this one:
    It too had a problem similar to what you're describing except it would cycle up and down a few times, then flag a PCOOL error on the control.
    Taking the cover off, I discovered that the limit switches were not activating properly. It uses a lumpy cam that clicks one switch for each position and another that sends a limit signal at the end of travel to establish a 'home' position.
    In operation, the nozzle travels to it's limit (triggering the home switch), then counts the 'lumpy' clicks down from there.
    In my case, the 'home' switch wasn't being activated properly. It would hunt up and down, not find home, then error. It's bumped by a small spring lever that had simply fatigued. A pair of needle nose pliers and a gentle nudge is all it took to fix it. It's been fine ever since.
    Greg
  1. makita router rpm constantly reving up/down any one had this problem?
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 05-19-2020, 08:11 AM
  2. PCOOL (Programmable Coolant Nozzle)
    By HelicopterJohn in forum Haas Mills
    Last Post: 11-10-2009, 05:59 PM
  3. Constant Velocity Mode CONSTANTLY DIES!
    By backlashphoenix in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2007, 12:52 PM
  4. HRT 210 homing
    By JAVB in forum Haas Mills
    Last Post: 12-07-2006, 07:44 PM
  5. homing vs 0,0,0
    By planeflier in forum Mechanical Calculations/Engineering Design
    Last Post: 02-08-2006, 04:02 AM
