587,223 active members*
3,087 visitors online*
Thread: VF-4 battery
Results 1 to 6 of 6
    Dec 2013
    VF-4 battery
    Where is the battry located & how do I replace it?
    Oct 2011
    5
    it is on the main mother board usually found on the top left side. You usually have to take out one or two other boards and a whole lot of cables to get to it. You have to solder in the new batter without disconnecting the old one. Then remove the old battery. Its a little bit of a process. I have done it successfully once. The second time it lost all perameters and came up with a ton of errors.
    Feb 2010
    1184
    Quote Originally Posted by durb69 View Post
    There is a plug connector, right next to the main battery, to attach a temporary battery to hold all parameters and software while the old battery is changed out.
    Feb 2011
    9
    Yes the battery is on the Processor. If you do not have a temp external 3vdc battery you can plug in, definitely back up and save all parameters and settings, macros,offsets,programs. How old is this machine?? If you have a USB drive you can do an "auto save all" check battery voltage first as well, I have seen several processors go "dead" and simply throws out a 124 low battery alarm, when in fact it is the processor that has died.
    May 2013
    17
    Battery Replacement Procedures
    Quote Originally Posted by ktmflyer View Post
    https://www.youtube.com/watch?v=JJZyv4rvR_8
    May 2013
    17
    Re: VF-4 battery
    Haas TM 1P Battery Replacement and Full System Recovery Repair (Error 250, Error 124, Error 475)
  1. alarm 124 low battery
    By metaler in forum Haas Mills
    Last Post: 01-22-2018, 09:35 PM
  2. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  3. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
  4. Battery charging??
    By Nastyzen in forum Colchester Tornado lathes
    Last Post: 02-22-2011, 02:17 AM
  5. battery alm
    By Drye-123 in forum Fanuc
    Last Post: 12-18-2008, 03:26 PM
