603,896 active members*
4,996 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > vf2 setting for 8x program names?
Results 1 to 4 of 4
    Oct 2007
    16
    hello, i was wondering if there is a setting on a vf2 ss non usb/ethernet that will let me save program names to 8 numbers instead of 5. I read about some machine having this setting but it was a while ago and can;t remember if it was for hass. Not at work so i can;t check ,...
    thanks
    Jul 2005
    12177
    The program name; that is the Onnnnn, at the top of a program is one letter and five numbers.
    The file name under which so save a program onto a usb drive or floppy uses the normal 8.3 format; i.e. ABCDEFGH.txt
    Or you can use the Program name Onnnnn.txt
    Or for that manner any name that works for Windows; only the first eight characters will show up in the directory list on the Haas when you open the usb or floppy.
    Oct 2007
    16
    Thanks for the quick reply, yah that bit me today, haven;t seen o2222~.txt in a while, like since windows 95 or 98. I made the mistake of copying my laptop "O2222 v1.5 1 1/8 - 20.txt" to the cnc and it truncated the file.
    But what i was refering to was a post somewhere i saw that some machines have a setting on/off that lets you specify Onnnnnnnn instead on Onnnnn. I may of miss read it, it was almost a year ago,.
    Jul 2005
    12177
    Are you sure it was referring to the program name? I while back Haas did change things so the line numbering could go above 5 digits; now I think it is possible to number up to 8 digits, 10 million lines. But I have never seen anything about the program name being different.
  1. Names
    By ErnieD in forum Trade Shows / Webinars / Other Events
    Last Post: 03-20-2007, 10:48 PM
  2. Setting or Program fault?
    By Kiwi in forum BobCad-Cam
    Last Post: 04-28-2006, 12:42 PM
  3. List of program names and #'s
    By daking in forum Fadal
    Last Post: 01-17-2006, 04:39 AM
  4. NAMES Expo
    By johnbutler in forum Trade Shows / Webinars / Other Events
    Last Post: 04-14-2004, 02:57 AM
