587,669 active members*
3,814 visitors online*
Results 1 to 11 of 11
    Mar 2006
    21
    VFD control on a Multicam
    Greetings,
    I just picked up a used Multicam MG204 with a 4 hp Colombo spindle.
    I want to replace it with a spare 10 hp HSD and Yaskawa VFD.
    Unfortunately, the Yaskawa model does not do MODBUS. Is it possible
    to configure a Multicam to control a VFD by another means other than
    MODBUS.
    Prior to this MG204, I'd had AXYZ machines. They didn't use MODBUS.
    They used EMOP to control the speed. If your VFD didn't have EMOP,
    you could still configure it just to start and stop at whatever speed you
    had the drive configured for.
    I'd rather not spend $1200 for a VFD when I already have 3 on the
    shelf.
    Any insight is greatly appreciated.
    Rich
    Jun 2010
    463
    Re: VFD control on a Multicam
    Yes inside of the parameters for your Multicam you can disable mobs, you will most likely have to use a pot for speed control.
    Jan 2008
    35
    I to picked up a used Multicam MG204, extra, couldn't resist it :->
    just today I was looking at the (small) VFD that's in there and noticed it wasn't driven by mod-bus like my other MG204
    it's most likely 0-10V ( maybe 4 - some mA )
    its connected to connector bottom-left on "the brains", marked S1
    same connector where the 5V comes in
    Mar 2006
    21
    Thanks for your response. I haven't had a chance to power it up again to test it. I can live with with a pot. I've got one already but it's not too speedy.
    Mar 2006
    21
    That's good news. Could I ask if you could post a couple cell phone pictures of the connections. The one at the inverter and the one at the M24 board. Thanks a bunch. Best Regards. Rich
    Jan 2008
    35
    Jun 2010
    463
    This control board is a older style, Modbus wasn't used consistently. Normally is your control board combo front/rear control boards m24rev 5/k520 rev 5 control boards, Modbus was generally used.
    Jan 2008
    35
    to me is the newer board, it's been put in ~8yrs(?) ago
    i do have an older board laying around
    this is the running the ATC-firmware
    I took it out of a 1 tool machine, VFD is now running on modbus
    this is how the analogue control was wired
    Attachment 278060 Attachment 278058
    Mar 2006
    21
    Sorry I've not responded sooner. Thanks for posting those pictures. I finally had a chance last weekend to try wiring up another VFD without modbus. Unfortunately, I couldn't get it to go. There are two wires I couldn't track down. In the photo, they are under 760 and 3041. Both appear to be black.
    I'm up and running none the less. I just wired it for manual control.
    Thanks again for your help.
    Rich
    Jan 2008
    35
    running VFD on 0-10V, quite easy . . .
    connector PH1, bottem-left, 9 pins
    feed 12V from external ps, very little power needed,
    pin 5 : 0V
    pin 9 : +12V
    pin 6 or 7 or 8 : 0-10V tot vfd input
    open "MotionMechanic"
    type (copy/paste) :
    196 get_integer .
    if not set to 0 yet
    type (copy/paste) :
    0 196 set_integer
    and again to make sure :
    196 get_integer .
    do :
    Reboot - Load Init File
    this worked for me, although, when running spindle warmup, at the end of it the VFD keeps running the last speed, doesn't go 0 rpm
    rpm can be lowered on pendant though
    didn't try what happens when running a program
    Mar 2006
    21
    Thanks for your help.
    I'm away on vacation but I'll try it as soon as I'm back.
    Best
    Rich
  1. Replies: 3
    Last Post: 03-11-2015, 01:26 AM
  2. Multicam HELP? 3000 motor fault Multicam motor fault (0x 4
    By murfeedean in forum Multicam Machines
    Last Post: 11-05-2012, 02:22 PM
  3. Control software for multicam m series??
    By IsaacD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-14-2012, 06:34 PM
  4. Looking for a Multicam M24 K520 Control Board
    By Chiefst in forum Multicam Machines
    Last Post: 12-08-2011, 11:08 PM
