588,137 active members*
5,758 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > VFD sizing with 4kw (5Hp) HSD ATC spindle, 220v single phase input
Results 1 to 9 of 9
    Feb 2008
    216
    I’ve been reading around and noticed that Hitachi is a popular VFD on this forum. I don’t want to have to reinvent the wheel so I’m hoping to be able to get a VFD that works for the Spindle I’m about to purchase. I plan to run Mach3, and I think that these VFD's take a 0-10v input and 2 other inputs for rotation direction?
    I’ve seen that the majority of the VFD’s that are dual rated for single phase/3phase inputs tend to stop at 3hp.
    The spindle I’m going to get is 4kW, (5hp)
    At full speed (continuous operation):
    Rated power : 3.8kW
    Rated Torque:1.5 Nm
    Rated Current:14.4A
    At full speed (60% duty cycle):
    Rated power : 4.6kW
    Rated Torque: 1.8Nm
    Rated Current:17.3A
Name:	HSD Spindle Spec Sheet.jpg
    Based on this info, I’m assuming that since I have a single phase 220V supply in my work shop, I will need to get a 3phase input VFD rated for double the max spindle current. ~35amp.
    I read another thread on here where it was suggested that the Hitachi WJ200-055LF or -075LF will be suitable?
    WJ200-055LF Inverter, 200 volt, 3 phase, 7.5 CT (10 VT) HP, 25.0 CT (30.0 VT) Amps
    WJ200-075LF Inverter, 200 volt, 3 phase, 10 CT (15 VT) HP, 33.0 CT (40.0 VT) Amps
    Which should I purchase? I don’t want to limit performance or damage the spindle by going with the cheaper option, but I don’t want to throw away money when I don’t need too either.
    When would I see currents that high? During start up? Would it ever get that high during normal operation?
    Thanks for any feedback in advance!!!
    Dec 2003
    24220
    AFAIK Hitachi have dual models, 3ph rated and 1ph versions, so there would be no derating for a particular model.
    With a VFD you do not get the inrush you do on a normal uncontrolled motor, VFD types that derate for 1 ph means that you would not be able to get the full performance of the motor if you used the 3ph motor rating.
    Al.
    Albert E.
    Feb 2008
    216
    You are correct, all Hitachi VFD's can operate with 1 phase input.
    Here is Hitachi's Sizing Guide:
    Application: Sizing 3-Phase Inverters for Single -Phase Power Applications
    So I'm pretty sure i'll be going with the WJ200-075LF Inverter, 200 volt, 3 phase, 10 CT (15 VT) HP, 33.0 CT (40.0 VT) Amps.
    Do i need any inline reactors to cut back on interference?
    Dec 2003
    24220
    If I was going to use just a single reactor, I would use it on the motor side rather than the input.
    It is easier on both drive and motor, especially if the motor is not Vector rated type.
    Al.
    Albert E.
    Feb 2008
    216
    What is vector rated type? How do I find this out?
    Dec 2003
    24220
    Usually is says on the motor plate, if it is a standard older motor it won't be vector rated.
    Al.
    Albert E.
    Feb 2008
    216
    I think the name plate i posted in my first post is what will eventually end up on the motor when it arrives....
    Dec 2003
    24220
    One thing it doesn't seem to show is the rpm (2 pole 4 pole?).
    Al.
    Albert E.
    Feb 2008
    216
    It says 2pole on the plate.
  1. Bridgeport R2E3 delima, 220v VFD 3 phase Versus 220V Single Phase
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2015, 04:01 AM
  2. Replies: 14
    Last Post: 05-23-2013, 07:59 PM
  3. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  4. 3 phase input VFD for single phase input?
    By Redhead in forum Phase Converters
    Last Post: 02-27-2008, 05:30 PM
