586,055 active members*
4,176 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD spindle as drive motor
Results 1 to 5 of 5
    Sep 2017
    3
    I'm considering building a CNC Machine center using the R8 spindle and mount off my X2D from Little Machine Shop but replacing the tiny motor with a 2.2 kw VFD spindle as the drive motor with the stock gearing. I'm wanting to increase feeds and speeds and horsepower without going too fast for the material. I don't trust the ER-20 collet to hold the drive gear without slipping, though. Has anyone used one of these as a drive motor? How would I go about this?
    Jan 2005
    15362
    Re: VFD spindle as drive motor
    Quote Originally Posted by bk5629 View Post
    Do you have a photo of what you want to do with the ER 20 collet holder they are for holding drills, milling cutters Etc for machining
    Mactec54
    Oct 2004
    175
    You should check out the weight of a 2.2 kw spindle, which I believe is 12 lbs. I recall people needing to put springs on the base Sherline models to help the Z axis stepper rise.
    Steve.
    May 2013
    480
    the limit is almost always the machine, not the spindle hp.
    12 pound.. "allegedly" 2.2kw motor at 24000 rpm.. no the plastic gears can't handle that! (maybe with oil mist lubrication they could)
    and yes the er-20 collet is plenty capable of handling the torque. if its good for a half inch endmill, it can handle a drive belt or a plastic gear. you'll blow the gear up long before the collet slips on the drive shaft.
    Jun 2011
    692
    It's hard to find any belts, pulleys or gears rated for much over 10k RPM. I think that's the main reason this isn't something that's commonly done.
  1. AC Spindle Motor, Do I need a drive or VFD
    By Cartierusm in forum Spindles / VFD
    Last Post: 12-07-2016, 05:22 AM
  2. Which motor and drive for g0704 spindle motor control
    By JeffsInventions in forum Benchtop Machines
    Last Post: 02-14-2013, 01:15 PM
  3. Spindle drive/motor rpm.
    By hotrob1 in forum Fanuc
    Last Post: 03-15-2011, 10:18 AM
  4. Spindle Motor or drive
    By kcarey in forum Tormach Personal CNC Mill
    Last Post: 09-29-2010, 02:10 PM
  5. spindle motor/drive
    By don_don in forum Gecko Drives
    Last Post: 02-20-2009, 03:22 PM
