588,138 active members*
5,561 visitors online*
Thread: VFD tripping
    Feb 2014
    5
    VFD tripping
    Hey all, I posted a thread here last weekend.
    My VFD kept tripping and I couldn't tell if the VFD or the spindle was the culprit.
    I can't find that thread now, may be it was moved?
    Anyhow, turns out it was a short between my cable shielding and one of the motor phase wires. I had connected the cable shielding to my ground wire, so my best guess is when the phase wire started shorting to the shielding it was not getting enough power to the spindle so it was not turning fast enough so the VFD was doing it's job in shutting down to protect spindle from being damaged. Also explains why I had to start spinning spindle by hand so it would know which direction to go. Swapped the ground wire for the damaged wire and so far so good.
    It took me a week and the purchase of a new spindle and VFD to figure it out, so I though I'd pass along the info in case anyone else has the same problem in the future.
    Jan 2005
    15362
    Re: VFD tripping
    bentfab
    You are very lucky that you yourself was not zapped
    Your shield should not be connected to your Ground wire,your Ground wire & shield should be independent of each other
    The shield Termination should be as the photo
    Mactec54
    Dec 2003
    24220
    Re: VFD tripping
    However the shield and the earth ground should be at a common reference, i.e. earth ground.
    It appears the problem was the shield shorted to one of the motor conductors.
    Al.
    Albert E.
  1. SX3 Tripping RCD
    By Hamzter in forum X3/SX3/G0619/G0463
    Last Post: 05-30-2014, 08:39 PM
  2. G540 'tripping'
    By Claytonc in forum DIY CNC Router Table Machines
    Last Post: 01-01-2012, 12:48 PM
  3. tripping the overload
    By machinehead1970 in forum CNC Machine Related Electronics
    Last Post: 10-26-2010, 10:23 PM
  4. Circuit keeps tripping!
    By greasetattoo in forum Benchtop Machines
    Last Post: 06-01-2009, 03:10 PM
  5. fuse tripping on 201 @ ~30 IPM
    By cyclotron in forum Gecko Drives
    Last Post: 05-14-2008, 08:54 PM
